Headrest question
hcvone
Huntingdon Valley, PA - Town of Webb, NY
I have a 2019 rst Tahoe, are the headrest glued to the foam? I want to get them embroider and one person telling me it can not be done because they are glued to the foam, and another person saying they are not glued. Anyone do this? Anyone know for sure. Thank you
Big Mama
Virginia
Is there a zipper on the bottom or Velcro? Not for sure but I’d be surprised if it was. Either way when you take it to the shop they’ll fix you up
It's sewn on the bottom, have seen zipers and velcro, this is a first, thank you
push down around the edges where the shaft goes look on the inside and outside of the shaft for a small pin hole, if there is a pinhole stick a paper clip in to remove the headrest, you may have to push on the left and right holes at the same time if there is a hole on each side.
H
hcvone
I know how the headrests come out, same as my Escalade's which I had done, they were not sewn together like these. :)
Drewphil
