Need help with prolonged cold start...
cfmistry
So I replaced my sparkplugs last weekend, didn't have any problems or notice any issues. Since that time, when cold, the truck cranks for about 5 seconds before starting. If I leave it in "ACC" for a few seconds the fuel primes and starts normally; it also doesn't have any issues starting when warm. It didn't do any of this before. I'm also noticing some fuel smell when driving slow. Any ideas what I may have messed up / leaned on?
Thanks,
Cyrus
cfmistry
cfmistry
Well I crawled under the car and saw fuel dripping all under the gas tank... no need to even look on top. I guess it's just a coincidence that this happens when I change the sparkplugs...
HiHoeSilver
Away!
Chicago
Yup. Mine did that, too. One of the lines on the pump head is probably rusted through with a little leak. Changed my pump. All good.
HiHoeSilver
Away!
Chicago
poetically?
Lol. I wish. Fixed. Pic for good measure....
cfmistry
cfmistry
Thanks guys. Ordered the new pump from RockAuto for $200 (Delco) and my mechanic will put it in next week for $260. Not the cheapest repair but definitely could be worse.
HiHoeSilver
Away!
Chicago
Not too bad. You can do it yourself in a day if you're so inclined.
Kinda crazy that the label outlasts the metal.
Yup. I coated the new one in bedliner before I installed it.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Did you by any chance have a strong fuel smell aside from the long crank?
I had a bad fuel smell but no leaks at all, even had it up on a lift looking for a leak with another mechanic. I finally stuck my cell phone above the tank to get pics and I saw the rusted pump lines and fuel. But wasn't leaking enough to run down the side of the tank. These tanks have a sump built in around the top of the tank in that area so it can't drain well. IMHO that is what helps these to rust out in the first place, take a look:
dark_knight
Thanks! I just started noticing a bad fuel smell on my car. No leaks and can't see above the tank to see the sending unit.
89Suburban
SE PA
Yeah it was really frustrating to find. You can't get your hands in there to feel. I jacked the rear of the truck up and climbed up over the axle with a shop light and took pics with the phone.
dark_knight
Here is a pic of mine. Not as bad as above but still leaking fuel.
89Suburban
SE PA
There ya go!!!! That's a flex fuel pump. Were you able to get the lines off? Mine were frozen and would not.
dark_knight
Ha ha. I didn't do it. Too busy with working 16 hour days. The guy that did it told me he did have problems removing the lines though.
dark_knight
How do you know its a flex fuel? It is, just wondering. Got a Delphi replacement with a new gm ring.
89Suburban
SE PA
The flex fuel has 2 lines and the non-flex has one. I learned this trying to find the right pump for mine last winter.
dark_knight
Ha ha. I knew my car was a flex based on the emblem on the back. Never did put e85 in it yet. It is a 2011.
Durobans
