To delete or not to delete Z55 on 2013 Burb. F/R Coil spring part numbers??
fireburban
fireburban
MN
Haven't had time yet, have all the parts sitting in my shop ready to go. Supposed to snow 6-8in here tomorrow through Saturday. When the weather warms up it's getting done.
fireburban
fireburban
MN
Guys, it literally took me this long to get the rear done. Had too much going on with life, and was pulling a 10k lb. trailer around with no air in the factory shocks.
Anyways, I got the rear done, finally... Didn't take any pictures as I was in a hurry. I had to unbolt the sway bar links and brake line from axle. Replaced the factory springs with the Z71 springs (which were much taller, also put helper air bags inside coils) and ditched the coil spacers that came with the old leveling kit. Along with the bilstein shocks and the new springs it rides great. Already pulled the trailer (empty), with my old setup it almost bottomed out my suspension even empty, it rides much better as well with 30lbs in the bags. With my 2.5in ccm leveling kit on front it's very level.
I just need to run my front struts to a shop to have them swap out to the adj bilstein's and reassemble for me. I have all new hardware and strut mounts as well. Then it will be done. Had these parts for long time, and I've moved since I was last on here. Ready to get this done!
fireburban
fireburban
MN
Oh and today I ordered the full Front and Rear "Sport kit" from EBC. Yellow stuff pads and slotted and dimpled rotors f/r. These factory brakes don't cut it, even driving around without a trailer I feel these brakes suffer when you run a bigger wheel/tire combo. 305's or 295's all around make it tough to stop.
fireburban
fireburban
MN
Got the brakes installed, front and rear. Wow is all I have to say... Damn near threw my wife threw the windshield the first time she drove it. These EBC brakes are an awesome upgrade. Can't even tell I have bigger wheels and tires now. And towing I don't even feel the trailer (10k lb dump trailer). A great upgrade if any of you are looking, I used the yellow stuff pads with the sport rotors.
Tomorrow it goes in for the front strut replacement/swap, it will finally be done front to back. I'm going to keep the spacer (leveling kit) and put the 5100 bilstiens on the second from the top notch. I have new strut mounts and boots as well.
fireburban
fireburban
MN
I got the front struts installed yesterday. I had them install them with the bilstiens at the second from stock setting along with the 2.5 CCM strut spacer. Preload is a bit much, wishing I would have went to the stock setting, as it rides a little rough in front. It is exactly level with the rear. Pics to come soon!!! Overall I am happy, looks great, rides good!
fireburban
fireburban
MN
Well... I have to say this thing rides absolutely awesome. I take back what I said previously, it did seem harsh at first on the 2nd setting. But after I put a few hundred miles on it today, a 100% difference. They must have settled and had a chance to break in because the harshness is gone and it rides smooth as butter. Best 2 things I've done to this burb was the brakes and delete the Z55 Auto ride. Loving the ride with the Z71 springs and these Bilstein's.
fireburban
fireburban
MN
mikeyss
Longmont, Colorado.
When I was deciding on whether to keep Z55 or not, I had completely trashed one of the front electronic shocks (long story). It was a Saturday, and I had to get the Tahoe back on the road and not stranded on a lift, so I bought some quick struts through Napa to get me by. I absolutely HATED the way the front end dipped during cornering with conventional shocks. I found that The electronic shocks stiffen up during cornering and normal shocks don't adapt to cornering. After that, I decided to spend the money and buy the factory stuff. I also drive cross country twice a year, so that's another reason I wanted to keep the smooth ride. It's like driving my living room couch
fireburban
fireburban
MN
You'd be in love with these Bilstien's. My wife loved the ride in stock form, but she likes it even better now. I'd never go back at this point.
These struts along with the small amount of added preload make it corner great. Granted I'm lifted, 2.75 in front and 2in in the rear, the body roll and sway are hardly noticeable.
mikeyss
Longmont, Colorado.
That's pretty awesome. I did look at bilsteins, but I had them on a truck I used to own and were too firm fo me back then. I am just old, haha
fireburban
fireburban
MN
Nope I get it... I had the same thought about an old 86 toyota pickup I had for years. Put the Bilstein's on and they were pretty stiff. Different story on these tanks we drive!!!
wwiizz
