Steering sector 2006 Yukon xl
Woodblocker55
I have a leaking steering sector also I have to deal with . How many miles do you get out of one now a days . I know 70s and 80s at 150,000 miles there was normally about 1/4 inch play you could never get out . At 174,000 miles it might be time to replace it and hoses to hydroboost and cooler. [emoji15][emoji849][emoji52]
Sent from my LGL84VL using Tapatalk
Woodblocker55
Woodblocker55
Steering gear box ...is what Rock Auto calls it ...it's a $200-300 judgement call.[emoji106][emoji16]
adventurenali92
Big Bear Lake, ca
I’m at 123k and the steering gear box on my 2006 xl Denali is leaking. I’ve gotta replace it. Gonna have that done next week.
SnowDrifter
Sasquatch Country
140k here, '05. No leaks. Original pump, lines, steering box.
Play in the steering wheel is about 1/4" as measured from where you put your hands.
drowssap
Colorado
If just OEM replacement and you do not have oversized tires.... Delco Pro apparently is the only one that lasts a long time. Others may have more advice hopefully.
Woodblocker55
Woodblocker55
Are you talking ac Delco pro reman ?
drowssap
Colorado
I could be wrong but I believe all Delco Pro units are all reman units to begin with so do not search for reman specifically, just look up Delco pro.
Woodblocker55
Woodblocker55
Changing steering box any pointers ? I'm going to replace a leaking steering box and all the hoses .
Is there any other unforseen things I should replace ? On that system ? Should put new arm on the steering box long as it's apart ? Rigs got 175,000 on it . Also I found a used aluminum tinted matching paint back hatch in pretty good condition . Compared to mine .. ( it's all ripples surface by the wiper arm looks like body shop was rebuilding it looks kind nasty). How Rare is it find a matching color back hatch. Should go pick it up ?
Durobans
