Passenger heated seat
blazzinbird
Illinois
So the passengers heated seat doesn't work no lights on the switch. Do it have its own fuse?
if it has been used a lot generally it is the wiring, some of the wires get hot and burn at the connectors or grounds, or.... the actual heating grid burns out under the seat cover and has to be replaced. you can look in the owners manual and check fuses but if the fuse is burnt there is probably a reason why. If you do not have a owners manual you can get it on the computer for free
just google "online manual 2012 tahoe" or whatever year/make yours is, it will be the first or second result in google on the gm website.
Luggz
