Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
Chrismnj
NJ
I hear you about noise, everyday I hear something new from mine lol, anyway nice build!
I was gonna ask your opinion of the tensioner types. After seeing the pics of the spring-loaded type coming apart, I was convinced to go back to the LS2 (block in center) style. I don't care about noise- it can't be that bad. The Gen3s, for the most part, didn't have anything at all and they're not known for timing chain failures. I'm sure the spring style failures really aren't all that common. But, just the fact that there are actually parts to separate has me leery. The LS2 has the block style mainly to limit the chain's movement under high RPM deceleration, like between shifts. Otherwise, the chain is always in tension on one side and compression on the other. So, maybe it's a VVT thing, like the phasing action affects the way the chain whips around so it needs an active tensioner?
kbuskill
NE. FL.
I used an LS2 timing chain and the spring tensioner in mine. I would be afraid the block style, causing that much noise, would be picked up by the knock sensors and retard the timing.
randeez
randeez
south florida
I thought there used to be another style that looked like the block but had a spring loaded shoe on it as well
randeez
randeez
south florida
Oct 23, 2017:
Today...deja vu
First one did make it thru 2018 tho
Chrismnj
NJ
Friend of mine had some cylinder pressure issues and was harder to tune with VVT, finally decided to go without. I think he went with texas speed cam
randeez
randeez
south florida
It has served me well, I just wanted more adjustability with it.
Would prob benefit from a different cam but but there are other things I would change along with it. The vvt cam i have is from Texas speed, i emailed them a few times back and forth - they said i would see more power in boost but prob a little sluggish out of it with a different cam.
By swapping the block i'm hoping to start cam retard a little sooner and carry it out further in the rpm
randeez
randeez
south florida
engine is back in, bolted to bellhousing, converter bolts back in, starter in.....started throwing everything back on it, exhaust manifolds back on, intake's on, ignition coils, most of the wiring is back on.
still need to throw waterpump/accessory bracket on the front, put in fans, and all the turbo crap... prob few more days after work this week and it should be back together.
Maybe I missed it, but what did you do about the bent rod- replaced just that one?
randeez
randeez
south florida
front driveshaft, exhaust crossover, turbo, downpipe, wastegate, efans, waterpump, oil lines to turbo, accessory bracket with power steering pump (except pulley) and alternator all on this afternoon.
still need to:
put on charge pipes, remount intercooler, trucool 40k, front bumper, connect the downpipe to the rest of exhaust (vbands easy), coolant and oil.
If it holds together, AND OF COURSE IM VERY CONFIDENT IT WILL, i'll start on the fuel system. I had wanted to run as much of it as i could with hard line (aluminum or stainless) but just need to get it going for now before i keep breaking it cause *coughithrewinabiggerwastegatespringcough*. ordered enough braided ptfe flex hose for feed and return to get it going abunch of fittings etc
PG01
Up here to the right
still need to:
You ok? You seem to have a cough....
Ossipeelake
