HiHoeSilver
Away!
Chicago
Got curious to see how much oil was in the catch can. I think this is a lot for maybe 1000 miles? Maybe 1500
Hard to see in the black can. How much is it? Here's my last few at 6,5,4,&3k intervals.
HiHoeSilver
Away!
Chicago
About as much as your last picture. Assuming that's a standard plastic cup and not a 711 big gulp lol
It's a pretty little cup. Here it is next to a pint. Also, I am now cutting my intervals back down. Not because of this oil, necessarily, but my wear numbers broke trend on my last analysis, so I'm hoping they go back with a shorter internal.
Bombsquad85
Northern VA
That's about the size I figured So I dumped probably a little less than your last picture.
brian.roberts.1293
Durham NC
Ok fellas I'm looking at changing the fluid in my front and rear diffs and my transfer case as I'm not sure it's ever been done. I'm not positive which kinds of oil to get and weights could anyone help me out with the correct or recommended by you guys kinds and weights for each thanks in advance.
2004 Z71 Suburban Green I have a few upgrades done.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
upgraded to blacked out headlamps and turn signals with smoked fogs. also got the ac replaced last knight, ready for the texas heat this summer.
Your NP8 tranfer case code means it's a NVG246. Takes AC Delco Auto-Trak II fluid, which is blue. Should be right around 2 quarts; mine took a little less but YMMV.
Actually 2.4 quarts according to alldatadiy. I just ordered some for my Denali since it’s out while I have my trans fixed.
Edit: never mind. Mines the NVG 149. My Tahoe has the 246 and you’re correct, 2.0 quarts.
I had 3 quarts on hand when I did mine (NVG246) a couple of weeks ago -- you never know and I want to be pumping that stuff in only once. My son brought his little drill pump and it worked pretty slick -- beats the heck out of a hand pump for time and effort.
According to Haynes, '99-'01 apparently takes 2.4 quarts in these TCs, too, but 2002 forward takes 2.0.
Isaiah W
I got my new 20's mounted up today. I can't stop staring at it! It's a good feeling to see it all come together. I would consider my Tahoe almost done after this!
I had two shops deny putting them on since they're bigger wheels. What a joke.
05Single
afraid of the dark
View attachment 220238 View attachment 220239
Looks good!!! An Escalade rack would look good on there.
Had a couple shops deny mounting my Nissan wheels, because I own a Chevy. I tried to explain how bolt patterns work but they just looked at me crazy
Isaiah W
Truck looks fantastic.
Thanks a bunch!
I agree with you on the Escalade rack, trying to find one the same color on car-part within reasonable distance is tough. I wasn't going to put one on, but I think the chrome piece would compliment the wheels very well now.
Very nice.
Thanks Rocket Man! Big compliment from someone with trucks as nice as yours!
wwiizz
