Subwoofer options without losing cargo space. SWB
adriver
I see people asking different questions, about the same thing, and In the effort to try to answer this in one thread I'm going to try to list this proacitvely. This is about the three areas in the GMT820 (SHORT WHEELBASE) where you can mount a subwoofer without losing any cargo space behind the 2nd row. Those three locations are: The drivers side rear panel, under the second row seat, and the third place is in the center console. (I do know that somebody actually cut up the body to mount under the floorboard, but if you can do that, you don't need this thread).
FIRST AREA: Rear panel on the drivers side. On 01-02 NBS, there was a factory subwoofer option for an 8" subwoofer. This will fit in all years, you just need to move the mount. Here is the best thread I know of that will discuss what will fit in the factory enclosure.
https://www.tahoeyukonforum.com/thr...woofer-drivers-to-fit-in-01-02-oem-box.74175/
Later on it was moved, and the only mass produced enclosure (that I know of), is the MTX thunderform. They are incredibly rare to find. If you go to the Man Mall/junk yard, take a quick peek for one, and you might get lucky..
Your last option for this location is to make a custom box. Here are a couple threads that should at least give you enough of an idea.
https://www.tahoeyukonforum.com/threads/stock-location-subwoofer-set-ups.76441/
https://www.tahoeyukonforum.com/threads/custom-box-replace-factory-location.20475/
SECOND AREA: Under the 2nd row seat. There are several options.
The Q-logic single 10"
https://www.qlogicenclosures.com/co...res/products/q-logic-q-customs-ql-c1gma110a01
(This link shows this product will also work on NNBS crew cabs. Whether NNBS crew cab boxes can be used on NBS 2nd rows or not, is not something I know, but would be REALLY helpful if we did. If so that's going to add a lot of options).
https://www.crutchfield.com/p_044C1GMA11/Q-Customs-Factory-fit-Subwoofer-Enclosures.html
Supercrewsound.com 8" or 10" with your choice of carpet color. (I have used them before, great customer service, and they did a custom box (2" thinner) with custom cuts so I could put it in a reg cab and have the seats go ALL the way back. They are the ones that build the box, not just a middle man.
https://www.supercrewsound.com/00Chevytahoeutssingle.html
BrightStarCarAudio (most of the options you will see on ebay).
Dual 8" or 10" black or charcoal carpet.
www.brightstarcaraudio.com/index.php?route=product/product&path=274_101_119_277&product_id=681
Single 8", 10" or (the only one I know of that's) 12" with black or charcoal carpet
http://www.brightstarcaraudio.com/i.../product&path=274_101_119_277&product_id=1350
Now, I am sure there are more options on Amazon or Ebay, but this is what I have in my information, and I'm not searching endlessly.
THIRD AREA: STEALTH, inside the center console. In 2003-2006, Bose moved the subwoofer to the center console. Its a smaller subwoofer, and unless you already have a nice sub that fits, and you're on a budget, you can do better.
The other main option is the JL Audio stealthbox. Unless you find a used one that's empty, it comes loaded with a $300 JL Audio 10" W3v3 (which is a very nice subwoofer, one of the most powerful SLIM subs you will find). This is definitely the most expensive option you will find at over $600.
https://www.crutchfield.com/g_530/Custom-Subwoofer-Boxes.html?tp=113
http://www.jlaudio.com/car-audio-stealthbox-chevrolet-tahoe-full-size-suv-03-06-trucks-03-07
There are always custom made down firing boxes that could be installed here too. I am not trying to give every option possible, just to give you a good start, and a little more than the basic information to help you on your way. If people choose to add on to it, GREAT.
You will notice on the rear panel area threads there were a couple people who said they would custom build them for a decent price, but the two I have messaged to inquire about them, have not responded to me, nor have they have been on here in a while.
M1Gunner
Gainesville, Fl
Nice post. I just built vertically... 4 12’s and still have a decent amount of cargo space.
This is another option, though, technically it does potentially consume cargo space, but not "behind" the 2nd row seats. Mine is free-standing, downward-firing, with quick-disconnect wiring, so it can be easily removed, if the space between the 2nd row seats is needed.
A
adriver
Yours is in the second row, with captains chairs. Most, if not all of the 2nd row factory options will NOT work with captains chairs. That looks like it might take up a couple inches of cargo space. Definitely a good post to include.
RockTheHouse
I know this post is old, but I see you make mention of the sub woofer in the center console, what size is it if you know? Thanks
OB 04Denali
Long Beach, NY
Hey.
I fitted the kicker 6.75 woofer in there with some modifications and powered it with an external amp. Not to bad. Way better then stock though.
DAN
RockTheHouse
So it is for sure the 6.75in? How good is the overall sound from it now? And how difficult was it to get the center console out and to get to the sub woofer itself? Thinking about doing that myself but I couldn't find what size fit there, or any tutorials on how to even get the center console out.
Also, what sub woofer did you use specifically? Thanks for the info
OB 04Denali
Long Beach, NY
No problem.
I read about replacing subs there and I rolled the dice. Removing the center console isnt brain surgery but it is a job. I had to dremel out the cutout hole carefully just so it fit. Lot better then what was there by a lot. Definitely a project and would not rush it.
Here is the one I used.
.https://www.kicker.com/6-75-comprt-subwoofer-2-ohm
OB 04Denali
Long Beach, NY
Or even the sundown 6.5inch sub might fit, but not positive.
https://www.woofersetc.com/sa-6-5-sw-d2-sundown-audio-6-5-200w-dual-2-ohm-sa-series-subwoofer.html
Very nice looking box Motorsport. I did a similar box in the same area with two JL audio W3’s in a custom fiberglass sealed enclosure wrap in grey vinyl. Although mine is a 05 Yukon xl it still didn’t effect cargo space much best of both worlds in my opinion. Hits hard and still have total cargo area intact.
Very nice box Motorsport. I did a similar box in the same area with two JL audio 12 W3’s in a sealed fiberglass enclosure. In my opinion best of both worlds, great bass without sacrificing cargo area.
I didn’t think it posted apparently I am wrong...lol I guess this is a good way to get my posts up
OB 04Denali
Long Beach, NY
Good afternoon,
Where did you find that box from? Or did you make it?
Dan O
Good afternoon,
Dan O
Custom made. The box's internal dimensions were made to match the enclosure design specifications of the Audiomobile sub. This sub, which is not a pancake sub, was specifically designed to play well in small sealed enclosures.
Moose912
Indy
I have a JL Stealthbox already set up and ready to go. Was in my suburban for about 8 mo. Sounds unbelievable. Install isn’t hard just time consuming. JL offers install instruction on their site. I’m selling the box and sub as it doesn’t fit in my Denali. Asking 350 plus shipping. Think I paid around 800.
OB 04Denali
Long Beach, NY
Throwing this out there. Has anyone tried fitting that pioneer shallow 10" box behind the back left panel? Mounting it is something else, but standing that box up vertically, do you think it will fit? Then bracing it to the frame somehow ? Just an idea
Dan O
Capybarbro
