Gmpartsdirect.com Or???
Rozay
so I looked at their site, I’m in need of new rear shock bolts (upper and lower) as well as sway bar link bolts (both sides as well) for the shorter links for a lowered application. I can’t find them on there. I was wondering where else should I look or does a sponsor on here have some. Thanks!
Hi-psi
Atlanta, GA
Normally I use https://www.gmpartsonline.net to get the part number, then search for the cheapest price between eBay, Amazon, RockAuto, etc.
A lot of the online GM parts sellers like Tasc, GM Parts Direct, etc will have cheap prices listed, but then ****** you on shipping. I've had hit/miss luck getting local dealer parts counters to match the online prices.
intheburbs
SE MI
For small things like that, isn't it just easiest to go to your local dealer? That's what, $20 or $30 of fasteners, at most?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
shock bolt upper and lower
gm#11611959 $5.99
shock nut
gm#11516382 $1.68
sway bar link bolt
gm#11609243 $5.75
sway bar link nut
gm#11516078 $5.25
Rozay
Rozay
Yea I cannot find them separately. Thanks for all your help guys.
meandmyhoe20
