OBS to NBS seats in a Tahoe
On3honksgo
I just picked up some super nice Grey NBS seat at work for $50. Anyone have move info on how to mount NBS seats in a gmt400 as far as how the brackets look and wiring for it to work. .... I have just heard a bunch of people saying they've done it but no one really says how, or can point out where some one did a write up
Big Mama
Virginia
Do they both have power seats? Does the obs have an airbag? Start with simple measurements of the mounting holes if they’re the same have at it and see if the connector match if not you may need to take the seat base off your seats and mount them to the new seats even if you need to drill a new hole that’s the easiest way to get them to fit remember to use your mounting bolts. No need to mess with seat belts but check the wires on it.
warndogg
Yes OBS has airbag but not in seats. Both are powered. I am hoping that I can get away with just drilling and tapping for the NBS seats if needed. Can't believe there isn't a write up for this.
best way is to just take current seats out and start troubleshooting and seeing where it leads you :shrug: Probably is not going to be rocket science but probably won't just bolt up either.
warndogg
Well I tried this weekend and the NBS seats wont fit. The ones I had were out of a 03' yukon Denali. The tracks are spaced too wide (about 4 inches wider). There is not enough space between the trans hump and the door.
Shadowz Edge
If I was able to find some NBS Power seats with the integrated seatbelts locally I'd work on making them work
Yeah, will definitely take some ingenuity and fabrication. Definitely doesn't surprise me that they don't just drop in and ready to rock.
Squirrelsmith
Modify the nbs mounting brackets. You can see what needs to be done, make it happen
warndogg
Has nothing to do with the "mounting brackets" if it did I would have put the seats in already. The tracks are too wide!! Like I stated previously too wide to fit between the trans hump and the door. So unless you have done it I am saying it cant be done.
DDRaptor
So I researched this for my 96 2 door and found on another forum where a guy did this in chevy truck. Same setup we have, and he used sets from 2006. That being said he cut the seat mounts on both and welded them together. Sounds easy enough. Another was a video I found where they cut into the trans tunnel just enough to add that bracket. Seems they only had to do that on the passenger side. So there re 2 different ways. Hope this helps out.
Sent from my SM-G975U1 using Tapatalk
