i read in my manual if you manually move them in or back out they will move at hwy speed, then you need to rest them. its simple, open and close them 3 times. you might hear a loud click, thats the motor re catching i suppose.
So they need to be attached and plugged in to reset them? 3 times.......
@Tonyrodz this is from my 2004 manual:
Scottydoggs
NJ
yes, the motor needs to run in and out a few times to make sure its back in order. so they need power to them at least. mine also work key on or off.
when i went buy mine the dealer had it on the street and was pushing the d/s mirror in and out, i thought nothing of it. till i read that in the manual not knowing if i had power fold or not i tried it out and boy did it make a click! i use them every time i park. kinda wish they folded in when you locked the doors like the newer trucks, but ehh is what it is right?
TP143
anyways, finally got off my ass today and installed my 2nd pair of retrofits
I made a new set for 2 reasons:
1) I hate the amber reflector on the OEM housings
2) I spent like 16 hours on my first set, and wanted to prove to myself that I could do a better job the second time.
My initial cutoff was:
and now it is:
and my long awaited DIY video:
Where did you get the headlights you used for the retrofit and where did you get the parts that you used?
06JET
Wisconsin
Scottydoggs
NJ
The car looks great. I like the paved driveway with the edging also.
thanks on both. sadly the driveways not mine....but i did help install it lol those pavers go front side walk to the garage, then flow into the back yard. that was a lot of hard work. so glad my friend hired a crew to do most of the hard work. the installing the base was the most work. had to dig up 6 inches of dirt then stone then stone dust, making each layer level and pitched.
http://s1097.photobucket.com/user/s...iveway?sort=3&page=1&hotlinkfix=1552614970076 few pics of the install.
brian.roberts.1293
Durham NC
But if they won't fold at all with the switch, how can I fold and unfold them 3 times?
So look when I go thru the car wash it will push the mirror in sometimes. Then my motors will not work until I get out and fold the mirrors all the way in and back out on each mirror manually then the motors will grab and start working.
2004 Z71 Suburban Green I have a few upgrades done.
eohat
In Torque We Trust
Mike @ Altitude 5,280 ft.
I picked up a pair of power fold mirrors a while back and was able to get them to fold/unfold by applying power to the correct pins with a 12V wall wart power supply. I don’t recall the correct pin numbers on the plug but you should be able to find that info on the vehicle electrical schematic.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Anyone know the RPO code for keyless entry on the '00? Trying to figure out if ours has it or not so I can get key fobs... I would imagine it does since it has leather, puddle lights, powered/heated mirrors, and all the other crap it has on it.
Put the Esky hatch on.
Before
After
Put on some 305/45/22 Toyo Proxies i found on craigs. Fills out the wheel well better than the 285/45/22s. Also gave it a quick wash.
Oh man... this makes me want the Esky hatch even WORSE. Love the way that looks.
Yeah... thanks for the helpful instructions, GM. :flipthebird:
Sam Harris
Can’t imagine any vehicle 2000 or newer not having keyless entry, regardless of trim level. [emoji3166]
Galandorian
Albany, New York
Well I'll be damned, I guess I need to get into the lithium game if its putting up numbers like that for that cheap. And at maximum I really would only need around 5k if I build upon this setup. Are they safe though?
we've done testing by throwing them off balconies, shooting them with assault rifles, puncturing them with arrows, etc, and have yet to see a fire that I'm aware of. with these specific Ford Cmax hybrid cells anyways.
like any battery, there's always a risk, but these seem to be very low on the risk spectrum
After
damn son, I never knew that was a possible alteration, that looks amazing
all links are in the youtube video :)
headlights - https://www.ebay.com/itm/Chrome-Cle...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
bracket - https://custom-brackets-designs.mys...-z3OnUDqjSyj3IBtxPv3ggzQxtnRjamgESD2po1vVx93s
kit - https://www.theretrofitsource.com/c...al-kits/bixenon-morimoto-mini-h1-stage-3.html
ASG-MikeS
