Shock install 99 Tahoe
4myfreedom
Washington, DC
Man this is a nightmares this shock will not go in in the leech bent or what. Bolstering shocks have thicker bushings at the bottom. I hate giving up!!!
4myfreedom
4myfreedom
Washington, DC
That Bilstein shock
Big Mama
Virginia
Can you widen the shock mount without damaging it? If not replacement mounts can be had.
Big Mama
Virginia
If you can widen a little and the bolts fit squarely I’d go that route but look on line for wider mounts they’re not usually very expensive. Try @NORCAL SS id bet Tony has a solution
4myfreedom
4myfreedom
Washington, DC
Thanks so it feels good to get help when you need it
Hodmjstone
