PG01
Up here to the right
Alright... this is the final rendition of the exhaust on the Burb.... I swear.... at least this week... lol
I ended up having them add the factory resonator back in at the tail to get rid of the awful drone it had at 60 MPH. This did the trick... no drone at 60, 70, or 80 mph on the interstate. It also toned it down a bit inside through out the RPM band although it doesn't seem that much different outside.
The best part about it was they didn't charge me for cutting and welding the resonator back in... so win, win for me.
I also have the dealer accessories optional chrome BOWTIE tip if anyone is interested check the classified section...
Questions, comments, criticism, all are welcome.
Question- do you like it?
Comments- thats all that matters
Critics- f ‘em
Ps- sounds good
Chrismnj
NJ
I think is just right
kbuskill
NE. FL.
Man, that sounds like Lieutenant Bullitt's Mustang! Sweet!
Ok, so give us run down of what you did from the heads to the tailpipe again to recap.
JBA shorty (cat4ward) headers with titanium ceramic coating.
Custom 2.25" Catless Y-pipe which comes back about 1.5' - 2' further than stock before it Ys together.
Magnaflow XL 3 chamber stainless steel muffler part #13749. Case length 30". Overall length 36".
Factory tail pipe with factory resonator reconfigured to exit out the rear through a 4" stainless tip.
I was going to post pics of each section of the exhaust but then I remembered that my SD card got corrupted and I lost all those pics. So I just posted some shots of the tip and resonator I took today.
***EDIT***
I went back through my posts and downloaded my own pics so that I can have them on my new SD card... lol
I will repost this post with pics included as I already have to many pics in this one.
Coming out the back kinda makes it look like it has the 6.2L... only someone from this forum would recognize that though... lol
kbuskill
NE. FL.
Also forgot to mention I got my new hoses made up today for my dual remote mount oil filter setup and oil cooler....
They are hydraulic lines with swivel threaded ends.
My only concern is the 212° max operating temperature but I have never seen my oil temp over 210° (after WOT pulls) and it usually sits about 205° when idling. Probably cooler when cruising due to more airflow over the oil cooler.
I figure that the maker probably tested it to higher temps and chose a safe number to list as spec. I seriously doubt that at 213° it fails.
The guy making the hose for me told me he makes them as oil lines for tractors and stuff all the time with no issues.
Hopefully this will alleviate the very minor leak I have. It's so minor that it doesn't even leave any drips on the ground but it's enough to annoy me just knowing it's there.
97audia4
This has me excited to have my 6.2 back after the long tubes and ORY are installed. I am keeping the factory muffler and resonator too as I heard most people delete it complain of the drone. I tow 6 to 8 hours at a time and dont want to deal with that.
kbuskill
NE. FL.
Yeah the ORY not having cats will definitely increase the volume/growl from that bad boy. I will be interested to hear it through the factory muffler and resonator as well. Please be sure and post a video when you get it back.
St. Louis
I plan on keeping my Denali quiet.... Well, stock quiet for a 6.2.
If I want loud I also own 2 mustangs. The loudest one is my 95 5.0 that has a built heads/cam/intake motor with Vortec supercharger and meth injection. 600hp through longtube headers, off road (cat-less) X pipe, and MAC mufflers and tailpipes, all 2.5". Yes it has a 2000 rpm drone inside, but the wine/whistle of the blower makes ya forget about it.... Lol
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
kbuskill
NE. FL.
This is where the factory Y came together just in front of the transmission crossmember by the transmission pan.
and this is where it comes together now about 2' further back just before the next crossmember.
Sam Harris
Yes, not a lot of snow here, but 60-70 mph winds. Apparently it’s a “Bomb Cyclone” now.
93blkongreenpro
Got it inspected by the dealership today. As soon as I left, maybe 5 miles, the check engine light for the s2d2 o2 sensor came back on, lol. I went through my radio, cleared it as I've done 40,000 times and kept it moving down the highway. I'll get that bung fixed one day.
Sent from my SM-N950U using Tapatalk
mtc1328
Indianapolis, IN
I had 20% tint applied to my front windows today to match the factory tint on the rear windows. I like the look a lot better with full tint. I would love to go darker, but I don't want any unnecessary attention.
I then came home and removed the center speaker on the dash so I could fix the excessive bouncing, as the retaining clip on the small dash separated from the large part of the dash. I just used some foam to brace the two dash pieces and eliminate the bouncing. I previously had a business card jammed in there to separate the parts, as the bounce created noise similar to fingernails on a chalk board.
I also added some more foam to support the center speaker so it wouldn't crack my dash (like I read from @Doubeleive did), as I felt like I was one of the lucky ones....
I ended up cracking the dash. Right by the upper left corner of the airbag. Like everyone else. I guess I'm part of the club now.
Escalade2007
