Custom Headliner
CJ Rodarme
Kent, WA
I just purchased some of the materials I need for my rolls-royce style "starlight" headliner. However I am not sure how many cans of spray adhesive I need. I plan on using foam backed black suede and stripping the whole board using a nylon wire wheel. I live in Western WA so it doesn't get terribly hot but between heat and vibration from my sound system I am worried about having a sagging headliner, especially with how many hours I'll be putting into the lights. I don't want to end up with a sagging headliner a year after I do it or anything like that. So for those who have done headliners how many cans of 3M are recommend?
CJ Rodarme
CJ Rodarme
Kent, WA
After talking to one of my friends he suggested I don’t strip the OEM liner and just layer the suede over it. This way I don’t have to worry about sagging. However I don’t know how clean it’d be.
mikeyss
Longmont, Colorado.
IMO, you never layer over headliner. If the OEM starts to come off, the expensive suede comes off with it. I know my 05 Tahoe the headliner is coming off around the front door area, so if I were to layer over that, it too would sag. Not only that, when you go to put the dome lights back in, the 2 layers of headliner would not let the lights sit flush. Do it right, remove and clean every square inch of the headliner, then install your suede.
CJ Rodarme
CJ Rodarme
Kent, WA
Okay thank you for your input. Do you think weather where you live had any effect on the sagging?
EfiniMotorsport
I work at an upholstery shop and do at least a few headliners a month. You HAVE to take off the old liner. Suede is much harder to work with than regular headliner material because it doesn't like to stretch. Make sure you have a wide enough piece after accounting for all the curves in the headliner. Covering mine was a pain in the ass. We use Stay-put contact cement. It comes in 5 gallon cans but I'm not sure if you can get it in aerosol or not. IF not I'd go with 3M Super 77 and you're going to need a lot of it. You need to make sure both surfaces are well covered before you stick them together. You also want to keep as much tension on the material before you stick it down. Cut an extra piece of the suede about 6"x12", coat the back with glue and fold it in half. Use that pad to brush the headliner down as you go. If you use your fingers you'll compress the foam on the back of the suede and leave noticeable lines in it.
Coincidentally I just did a black suede headliner and a fiber optic starlight ceiling in my BMW last weekend. It looks awesome but damn it took a long time and that was in a car with a headliner less than half the size of your truck. I used 197 points of light, 40 or so of which were in the sunroof slider. It took me 13 hours total including recovering the headliner. If you have any questions on it shoot me a pm.
CJ Rodarme
CJ Rodarme
Kent, WA
Would you recommend that I just take the headliner to a upholstery shop with it removed and stripped? I'm not sure how expensive it would be compared do doing it myself. I've heard I can save some money if I don't need it uninstalled/installed and have it prepped.
Fosscore
Man I want to see pictures of that starlight suede BMW headliner! :)
EfiniMotorsport
I don't know about shops in your area but it's less than half the price if someone brings us a headliner already out of the car. The problem is trying to move something that size when it's not in the vehicle. There's no good place to put it. This is the only picture I have of it right now. I still need to figure out how to get the 40 or so strands in the sunroof slider to not bind up when I open it.
I called up a local planetarium and had them send me a star map of the sky on the day I was born where I was born. It took me a little while how to lay it out in a way that would look random but not too much of a pattern. The BMW headliner was close to square so it was easy to scale it. Because the truck headliners are so long it would take a little more work to get it laid out right. Just tell them how many "stars" you need based on your kit. Make sure the strands reach all the way too. You may need two kits and to mount the controller in the middle of the truck. Maybe in the B or C pillars.
A wire wheel in a drill works great to strip the old foam off the board. Just make sure that you only run the drill one way because the bristles will take a bend quickly and if reversed dig in. Also be careful around the edges and openings. You want the bristles to go away from the edge so they don't grab onto them.
CJ Rodarme
CJ Rodarme
Kent, WA
My kit is 800 stars... gonna be a fun couple weekends to say the least
select127
Florida
I had my headliner done in suede a couple years ago. Pulled it out and took it to a local shop. Only cost me $150. It was double that if they had to remove & install it.
I'm not a fan of any of the aerosol can spray adhesives. I replaced the headliner in my Jeep XJ with a fiber-backed vinyl intended for outdoor upholstery (heavy) and it's still like new. I used DAP Weldwood contact adhesive and applied it with a Harbor Freight paint gun
EfiniMotorsport
The spray type contact cements like Stay Put or that weldwood will work much better than anything in an aerosol can. Make sure you get good coverage but not to the point of soaking through. 2 medium coats are better than 1 heavy one.
CJ Rodarme
CJ Rodarme
Kent, WA
After some thinking I've decided not to do black suede... for now. My headliner is fine as it is now and I don't feel the need to do suede so I'm just gonna install the kit on the OEM. I haven't seen a whole lot of these done on lighter fabric and it won't make a difference when its dark, plus saves me some money :D. And when it does eventually sag I'll pull it, get it wrapped and do a new fiber kit with 1100 strands. So I'm not necessarily worried about doing it on the stock headliner, if it sags or gets ruined eventually its not gonna be the end of the world. However, I haven't exactly figured out how I'm going to run the fibers. My plan is to mount the box in the little box on the driver's side in the back for easy access and cut a hole through the side and up the rear pillar on the rear driver's side door. I have a poorly edited pic attached that shows the general idea. The green line represents the fibers (which will be loomed until the headliner) and the red line is the power wire that will have to be ran to the light box. However, I have no idea if that's even possible. I'm not sure how to pull those panels, and the research I've done so far hasn't brought any answers. So if anyone has any suggestions or can direct me towards a thread that could help me that would be greatly appreciated.
briannorris
