Sam Harris
Yeah, I see no reason why it wouldn't. There may be small differences in the length and arrangement.
For my '08 Denali it was:
Two 4in sections of 3in pipe (to join the elbows)
One 45 degree street elbow (connects to MAF)
One 60 degree regular elbow
One 90 degree street elbow (connects to throttle body)
Two 3in Fernco's w/clamps
One 3/8 barbed 90 degree threaded fitting
One foot of rubber 3/8 ID tubing
If I were going to build another one, I might try using a 60 degree street elbow in place of the 90 to connect to the throttle body. At least on my vehicle it kind of curls back a bit inside of the Fernco boot, making a not so smooth transition. The 90 degrees was a little too much. I think 60 would have been more ideal.
I drilled and tapped the barbed fitting into the backside of the 60 that connects to the line down near the top of the passenger side valve cover. Where the fitting goes into the 60, I used some liquid electrical tape to ensure I had an airtight seal. All of the unions are just glued with regular PVC cement.
@Hi-psi So.. I ah, got mine installed today:
kbuskill
NE. FL.
Definitely interested to see how this will sound. Been thinking of going with one of these for a while now, but looking at the shorter 27" body 2.5" since ill be using the factory 2.75" pipe. I've finally gotten to the point i don't want a loud vehicle anymore, yet stock is too quiet. Have had thoughts of 3rd cat, and rear resonator delete. But not sure it's going to be a big enough difference to be worth the cost. Had Gibson M.W.A on my Silverado and the "No drone" is true to a point, still had drone under load on highway and under accel in town.
Sent from my SM-N950U using Tapatalk
Mine may not give you an accurate depiction of how it will sound as I have JBA headers and no cats.
Removing the cats made a HUGE difference in sound. I was shocked at how much louder it was without cats to be honest.
Either way, I will be sure to post a video once I get it put on... I hope I'm happy with it.
97audia4
Dropped the Yukon off today to get long tubes and ORY pipe installed and then road tuned.
I know of one broken bolt on the passenger side and for the price they quoted to install and fix it they can deal with that mess.
Sam Harris
All you guys (and gals) out there make sure to keep a check on how many cranks you have left on your batteries. Wouldn't want to get stranded. :Big Laugh:
[emoji1787]:ROFL:
Sent from my iPhone using TapaBlah
Sam Harris
Temp got up to 37 here today, so I ran it through the car wash to get all the ick off from the snow/ice/salt
Oh, and low fuel warning came on so I filled up with 26 gallons of E85 @ 1.80 gal
Edit: Oh, the obligatory pic....
Damn, $1.80! I need to find some near me and try it out. I know it gets less mpg / slightly more power.. worth checking out for sure.
Fosscore
Clean pics always a win.
X-ray Nerd
