BAMF Pri's 2005 Chevrolet Tahoe build thread
73impala
73impala
Margate, FL
Got the escalade rear vent caps and third brake light back from paint. Need to install the third brake still.
20190216_212843 by James Pate, on Flickr
20190217_150242 by James Pate, on Flickr
Fosscore
Vent caps look good. I cannot recall, but you did get the Esky 3rd brake light right?
73impala
73impala
Margate, FL
HAHAHA yes escalade CHMSL need to get it mounted. Going to try just double side taping it, saw someone did it and never saw anything where they had an issue.
05Single
afraid of the dark
I've heard some people just using double sided tape and no issues. I was gonna do the same but make some flat hooks to curve around the top and attach to the base.
73impala
73impala
Margate, FL
Grille isn't painted yet. Going to have the grille, bumper plastics and mirrors done all together though. Got to save up some and then have them done. Still need to get the esky third brake installed though.
Fosscore
Cannot remember if I asked this or not, but you are CM the bumper plastics?
73impala
73impala
Margate, FL
Yup bumper plastics will all be color matched and then leave the chrome bumpers.
05Single
afraid of the dark
Well tahoe was overheating yesterday, thought maybe fans or water pump. Turns out it was neither just low on coolant, whew. Also purchased some JDMastar leds recently and replaced the old leds.
2019-03-05_08-31-51 by James Pate, on Flickr
I took out all my Chinese leds and replaced them with hem astars. I also roll with my rear headrests down too lol
73impala
73impala
Margate, FL
Crazy what an improvement. yeah no reason for keeping them down just never put them back up lol
73impala
73impala
Margate, FL
Well truck decided it was going to overheat a little. Looked at it was a little low on coolant so I added some. Checked the radiator made sure the water pump was flowing water and it was. Turned the ac on made sure the fans were working and they came on. But after I topped it off the temps didn't get above operating temps and runs fine. But I did find that the truck is throwing a p0342 code so going to have to replace the camshaft position sensor behind the intake manifold.
BUT I also did get the escalade third brake light installed. Used double sided tape on the entire thing and it seems to be holding on pretty well. But only time will tell. I did however have to swap the two wires going from the factory plug into the actual light. Question though, with the running lights on the outside three lights on either side of the third brake are illuminated. Is that normal?
Also still waiting on the color matched end caps for the roof rack to come back from paint.
Anyways onto photos.
LRM_EXPORT_1664973653861244_20190315_184251997 by James Pate, on Flickr
LRM_EXPORT_1664957487654219_20190315_184235830 by James Pate, on Flickr
LRM_EXPORT_1664970792510672_20190315_184249135 by James Pate, on Flickr
LRM_EXPORT_1664965448777601_20190315_184243792 by James Pate, on Flickr
LRM_EXPORT_1664968175238017_20190315_184246518 by James Pate, on Flickr
Fosscore
That Esky 3rd looks good. Slowly growing on me.
curbud
