Carbon fiber trim project
LanceD
AZ
My steering wheel looks like crap so I'm attempting to do a real carbon fiber overlay with resin to make it look nice. If it turns out good I might do the rest of the pieces.
Def wanna see it when it’s finished. Looks good so far.
992dr
Eastern N.C.
Oooohhh carbon fiber, nice. Lookin good.
Lookin forward to your updates.
LanceD
LanceD
AZ
First attempt = fail
Material lifted.
LanceD
LanceD
AZ
Damn.
How'd you prep and apply it?
I sanded it and used 3m spray glue to apply the cloth. Then coated out in resin. Turns out the resin makes the spray glue not hold.
Second attempt I put a coating of resin on the parts and after a few hours when it's tacky I'll apply the cloth. Then vacuum the pieces and see if it holds
992dr
Eastern N.C.
Gotcha. With the small amount of experience I have using resin and glass, I had the best results applying the resin to both pieces and waiting for them to get tacky, then applying.
Vacuuming them together, man now your stepping it up another notch haha.
I'm feeling good about this one haha.
I’ve aleays applied resin and cloth at the same time the few times Ive done fiberglass work. But I never tried to attach it to anything other than more fiberglass.
992dr
Eastern N.C.
Lookin good.
Did you prep the plastic with some sand paper before?
LanceD
LanceD
AZ
Yes I did. 220 I think
I may need to find a thicker resin so I don't have to do 20 coats. The stuff I have is thin for using in vacuum molds
Derick
Indy Suburbs
Man, that is going to look bad ass. I ended up just taking the time and some denatured alcohol to get the rubbery crap off the steering wheel, and was happy with it. If my truck was a show car, I would care more - what you're doing is going to look awesome.
LanceD
LanceD
AZ
I abandoned the silver looking carbon because it looked crappy after the weave moved from wrapping. Trying out regular twill weave carbon.
Attempt 3:
992dr
Eastern N.C.
How big of a station is that vacuum set up?
Did the weave move from the vacuum process?
How did you remove it?
Where do you get it from?
Love the look of carbon.
LanceD
LanceD
AZ
It's not really a station, just a car window.
the weave has to move to wrap around contours.
It peels off easy. It's designed to not stick
I get it from various places online. Whoever is cheapest
992dr
Eastern N.C.
Hahaha, gotcha.
I figured it would move but, didn't think it would move that much. Maybe the radius was too much.
Really, huh. That's actually kinda cool. If you don't like it, easy removal.
Cool, Thanks. Didn't know if you got it anywhere in particular.
I'm trying to remember the place I used to get my materials from but, its been so long haha, cant remember.
LanceD
LanceD
AZ
Hahaha, gotcha.
Actually I thought you were talking about how easy it is to remove the vacuum bag stuff. The carbon and epoxy is very difficult to remove once cured. Have to grind or sand it off or use a heat gun to soften then peel it back.
scottd
