I need TPMS Help
steve45
I guess you could duct tape the new sensor to a wheel and drive it for a couple of miles (I'd take the valve stem off). Or, you could mount them on a drill somehow and spin them for a few minutes.
C
CountryBoy19
Southern Indiana
My "service tire monitor" just came on...... I wonder if doing the "You Tube" test might show me which is bad, or maybe reset the monitors?
If they miss so many signal transmissions in a row it trips that message. It's an indicator of dying batteries normally. If you're quick you can often cycle through your tire pressures quickly and see which lists "---" but often times by the time you see the message and react its already gone back to normal. Just keep trying and you'll eventually see one blanked out.
Sasquatch
Orange County N.Y.
When i start the truck i get a message about them but i simply hit the button on the steering wheel and it`s gone. It bothers some people but i could care less because it takes one second to make it go away. It`s much easier than replacing those overpriced monitors.
HiHoeSilver
Away!
Chicago
You just burn out the yellow light, or what? Lol
Hodmjstone
