Trying to get low
Even when they do give you the print outs and some are in the red, "That's the best we can do because you lowered/lifted it". Yeah, I've heard that one before.
This is my point in my previous reply to you. Nowadays, big-name lowering components such as Belltech, DJM and McGaughy's have so much engineered into their products that proper alignment after the install should not be a problem. Hell, General Motors awarded McGaughy's for their lowering products!
IIRC, Sam used all top-notch products with intent. If I were him and a shop told me they could only do so much, I'd be asking questions. About the only issue I can think of would be lack of adjustability for the amount of drop. But, I think he took care of that with the Belltech camber eccentrics and even has/had the offset bushings.
I've never had a problem with an alignment of my lowered vehicles. Granted I do use quality parts but I think it's more of where you go. I haven't had The Machine aligned yet; it drives straight as an arrow. But I'd be curious to know if it can hold alignment all the way from slammed to raised almost all the way up. I know that unlike a lot of bagged rigs, the camber holds true no matter the ride height.
kbuskill
NE. FL.
I only take my vehicles to places that will let me stand in there and watch what they are doing.
If you want to tell me your insurance won't allow me to be there, then I will go else where... simple as that.
kbuskill
NE. FL.
Not doubting you, just curious... how was this achieved???
With regular suspension the control arms will pull the camber in and out with just the cycling of the suspension.
Custom control arms made to do it and heim joints for the steering.I’m not sure of the exact geometry involved since I didn’t do it myself but it’s pretty cool to watch.
992dr
992dr
Eastern N.C.
The top was when you brought the truck in and the bottom is when it left.
The camber is still off... only it shows positive camber which would cause the outside edges to wear faster.
Seems like something may be broken of loose. I do feel something in my steering during my short commute.
There are three dimensions to adjust for: toe, camber and caster. Well, there's thrust angle, but let's keep it basic. Toe and camber are the easiest to nail. Getting the caster set is a little more of a pain cuz it affects the camber when you adjust for it and vice versa. It can kinda be a balancing act. Also, if you have aftermarket control arms and/or spindles, the way the parts swing/tilt/articulate as the suspension is cycled when driving could be vastly different than with the stock parts. For instance, with the stock parts, the toe, caster and camber may only move out of their static settings a few tenths of a degree (just to throw out a number). With the aftermarket parts, the new geometry could cause the toe, caster and camber to swing more than a full degree(again, just throwing out a number) away from their static settings. This is why I asked if you felt a difference in the steering after it was lowered and aligned. A "drastic" (even as small as 1 degree or maybe less) change in caster and toe could very well make a noticeable change in the feel of the steering, especially when hitting large and shallow dips and humps on the highway.
Looking at the that printout, and as Ken pointed out, your camber is almost a full degree out with positive camber. I believe the stock settings call for a slight bit of negative camber. If so, you're almost a full degree out of spec on the camber.
Also, as Ken mentioned, positive camber would cause the outside edges to wear. I'm no expert, but that printout and your inner shoulder wear tells me that the tires are toeing out or cambering in as the suspension cycles, like there's a lot of extra movement going on.
I'd first make sure your parts are all good- no loose bolts, etc. and have another reputable shop check the alignment. There's a chance the first shop's equipment is out of calibration.
After driving for the past few days, I've noticed how my steering feels. Its definitely wishy washy. I'm going to have to get under it this weekend to check it out.
I'm going to look around for another shop to. The shop I had gone to, they do not allow customers out back. What's crazy is, I am usually all over them about watching but with an alignment, never thought of it.
Question--so the shops shoo you out the door with your alignment still not right because the average person doesn't know squat about alignment specs? Actually more of a statement I guess.
That was my whole point in using reputable components. Not really thinking the shop would slack. I'm finding it more common than not around here. You cant find good anything in this area.
The shop said "it was a little out" and "that's the best they could do" .
I had the alignment bushings installed but removed them after lifting it back up.
This shop does not allow customers in the back. I'm usually the one who is all but on top of the mechanic when I do drop my Tahoe off. This shop would not allow that though.
I may go look for another alignment shop, its just hard to find around me.
992dr
992dr
Eastern N.C.
Ok, finally had a little time to get under there and check things out. Actually literally just came in from looking. Looked under while my daughter was turning the wheel and everything looked good. Then I went to look at the rack.
I think I found my culprit.
Here's a question for you guys. Is the steering rack supposed to move when turning the wheel?
J/k, I know its not supposed to move :)
992dr
992dr
Eastern N.C.
Well, its been a while and I really have no suspension updates but, I do want to drop the rear another inch.
I have Tony's 6" coil with the isolator removed and heater hose around the coil to give me roughly another 3/4" but I'd like to try to get another inch.
How the heck can I achieve this?
Are any of the coils of that 6" drop spring compressed and resting on each other? IIRC, you could get an extra inch of drop from the 5" coils by cutting off some of the "dead" coils. They're compressed against the others so they're just acting like spacers at that point. Just have to be careful that the spring can still expand enough to remain in place if the suspension is unloaded during large amounts of cycling, like when ramping up on bigger humps.
Just bag the damned thing.
992dr
992dr
Eastern N.C.
Cant say I'm a fan of cutting coils. Was hoping there was a way to do without going that route.
I'm going to be getting under it this weekend to do the front and measure for my exhaust. I'll have to evaluate the situation and see what I can come up with.
What do you mean? I am bagged, they're stuffed inside the coils :D
kbuskill
NE. FL.
I have the 6" springs in the back of my Burb without the spacer but I still have the Autoride functional and the air bladders inside the springs.
Without the bladders and before I adjusted my Autoride links it sat lower but would bottom out over bumps. This was WITH the free travel mod.
I ended up cutting a notch in the crossmember between the frame rails to give the panhard bar bracket on the axle a little more room (you could see marks on the crossmember where it had been making contact). I also trimmed the "ears" on the panhard bar bracket so they didn't stick up past the bar itself.
Here is a pic of the area as it was from the factory...
You can see the squared off "ears" of the bracket on the axle and where they had been making contact with the crossmember above.
This is after I notched the crossmember...
And this is after I trimmed and rounded, and essentially got rid of the "ears" on the axle bracket...
I have the Spohn adjustable panhard bar... not sure if you could trim that much with the stock bar in place or not.
As far as going lower than the 6" springs... I think your ride quality will suffer tremendously, not from the coils being cut... but from the axle hitting the frame more frequently. I'm not sure there are many options other than cutting the coils or heating them (which is worse, IMO) without raising the upper spring perch which would take a ton of work (lifting the body off the frame).
Either way... I hope these pics help you out.
992dr
992dr
Eastern N.C.
Thanks kbus, I appreciate the pics. Gives me an idea of where and how much to remove.
This is similar to what I had to do to my 2dr with 4/6-5/7 drop. I had to notch every crossmember and frame. Its just a part of the fun of modifying.
I could notch the frame if I had to but, I'll look at it this weekend and see what's the best route to go. I was thinking coil-overs and TBSS bags. Not a huge fan of air but, the shockwaves are a nice compact package.
I understand not wanting to cut coils. As an old school method, it really affected the ride because some of the cut coil(s) were active coils so cutting them raised the spring rate. With anything ike the 5305 coils (I believe I have that number correct), there are a few "dead" coils that are just compressed and resting against the next coil. They are acting just as height spacers so cutting them wouldn't affect the ride at all. I'm sure you already know, but the ends of the coils are "pigtailed" and are a smaller diameter. If you were to cut, you'd have to look at the diameter of the coil you're cutting and see if it would fit inside the pocket since it would be the new end of the coil. The amount of drop would be equal to the wire size (thickness) of the coil multiplied by how many coils you remove. Rough estimate is 1/2"-5/8" per coil.
992dr
992dr
Eastern N.C.
I gotcha and understand completely.
I'll have to look at the pocket where the coil sits to see if its possible to this. I'll definitely check it out while I'm under there this weekend. Its more than likely the easiest route to go.
I wish I was ready to lower mine. I have a set of "mystery" coils that I'm gonna guess would yield at least 4" of drop yet might retain nearly-stock ride quality and load capacity.
Oh, if you do cut, a band saw or (ugh) hack saw would be best to keep heat to a minimum. If you use a cut-off wheel, just don't bear down on it. Let it slowly eat at it. And don't cut across the diameter of the wire, cut across the diameter of the whole coil so that the end wire tapers to a flat.
992dr
992dr
Eastern N.C.
What're you waiting for?
Good point. I'll use my band saw :)
Drewphil
