Steering box seal rebuild
DallasTahoe
Has anyone done a seal kit on a gear box before? Is it hard? Need any special tools? I’m needing to do my seals, or buy a new gearbox, mine is leaking from the pitman shaft seal. Any help would be appreciated
Erickk120
I've thought about it, mine was leaking and made a pool over time, I dumped some atp 205 and it stopped the leak, its a little moist at best but not even noticeable now, pitman arm is bone dry I know eventually I will have to replace it, but it has held for a year now, So I know its the seal being worn and not due to excessive wear in the components. I think I would be easier to get a reman unit to be completely honest, or that is what I will do if it leaks.
mtl111
Arkansas
I've never replaced the seals in one, I'm sure its not fun. If you have any "slack" in your steering box at all, I would just get a rebuilt one and be done with it. You'll have to pull it out of the truck anyway, so just put a rebuilt one back in. Just my opinion though!
Sent from my SAMSUNG-SM-G930A using Tapatalk
DallasTahoe
DallasTahoe
No you’re right, I was thinking about that too, and I’ve been trying to stick with the philosophy of “replace it, upgrade it” just didn’t feel like dropping a couple hundred bucks on it if I can fix the seal easily
east302
Mississippi
The pitman arm seal looks straightforward. Here is the manual for a 98, it says it can be done without pulling the gear though that seems like a major pain to do. I think it’s easier to pull the box and then hit the pitman arm puller with an impact.
DallasTahoe
DallasTahoe
Thanks for that diagram that will save me!! Already received the rebuild kit, and I have my evo delete thing, just gotta get a couple free days to do it
microfoxdev
