Turning off Headlights as DRL
Mickey_7106
Bay Area
i couldn't find any info on this. i would like to disable my headlights and keep the parking/turn signals on as DRL. I'm Planning on installing some switchbacks for this project
i'm sure you could just disable the drl feature and then run relays to the running lights instead or rewire it to power the running lights, it's going to be tricky though because the automatic headlight feature will then either power the running lights instead or won't work and you will need to turn the headlights on manually. might be easier to just install a toggle switch
St. Louis
Or just turn the dial momentarily after starting the vehicle. It turns all front lights off
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
BG1988
:rolleyes: works but christ I start my truck alot....
under the DIC you can have the lights not come on when you unlock the suv etc i think there is a setting to disable auto head lights as well
or you can put a 3000k LED on the light sensor or resistor (the light sensor is just a resistor)
Daylight
= 5 KΩ
Dark
= 20 MΩ
you can always probe it before adding your own resistor
Luggz
