Tonyrodz's Tahoe Build Thread
Scottydoggs
NJ
Where can you get those pids from?
they are in the app. just needs to be set up. i didnt have my glasses so i took what i could get to and see, then went back in the house. it was cold out. im gonna see if they got directions on line and give that a quick read if its there.
My new addition.
Now I just gotta install it.
Fosscore
Oh yeah. Next week we're supposed to get into the 50's, so maybe then. Didn't @Rocket Man get his tow shift button to work on his nbs? This is a 4 wire, ours is a 2 wire.
Hmm... cannot recall. Something about the orange wire IIRC....?
adventurenali92
Big Bear Lake, ca
Yeah I looked at that thread. Lol. But it doesn’t tell me which white wire is positive and which is wire is ground. Lol. I don’t like not knowing :eek:
kbuskill
NE. FL.
Truth be told... they are probably both negative.
One probably goes to ground/negative and the other side probably goes to the BCM and when you press the tow haul button it just grounds that wire temporarily which the BCM interprets as a signal.
Very common on GM vehicles to use a ground signal to turn things on and off.
95escahoe
Tow haul works on mine, I made up a harness so I didn’t hack up any of the wiring just plug it in and go
adventurenali92
Big Bear Lake, ca
Yeah that’s what I’m doing. Pulled a second pigtail from an NBS burb a while back from the junkyard. Cleaned it up and now it’s connected to the NNBS shifter wires. So that I can still plug the pigtail into my trucks wires are not cut anything on the truck side. Plus if for any reason I need to go back to my NBS esky handle I can and just unplug and re plug. Lol.
Drewphil
