Norcal 3-5/6 drop, what rear swaybar?
V30Crewcab
running the 3/5 drop, and have a hellwig front swaybar. bought a hellwig rear, and it wont fit. anyone running aftermarket rear swaybar with this drop?
You need a DJM endlink kit. It relocates the swaybar to the pass side about an inch. Ask Tony aka norcalss
1992rs
OR
Keep the hellwigs and get tonys hardware or contact hellwig. They have a rear swaybar kit that works for a 3/5 drop. Honestly, it looks like they just use some rectangular tubing to drop the mounts lower to clear. But definitely keep the hellwigs, they have the biggest rear bar and its adjustable nature makes it the stiffest rate out of the bunch for our rigs.
V30Crewcab
V30Crewcab
i have the djm endlinks. won't work with the swaybar I have. not enough space for it to be on the pass side.
adriver
The Hellwig is technically not the biggest sway bar, but it is the biggest one that is solid. Tthe one that is larger is tubular, and IIRC not adjustable. The Hellwig is the best bar you can get. When you think about what this bar does, its not worth trying to save a few pounds in exchange for strength. Then to add adjustability, it wins easy.
D Rollins
