Question about wiper blade placement
13yukonNJ
New Jersey
My front passenger wiper blade doesn't sit flush with the windshield all the way across. I buy 22" blades for both wipers in the front. The drivers one sits fine, but the edge of the passenger one (closest to the mirror) sticks up from the windshield. Once it wipes it makes contact, but in the resting position the outward edge (about 2 inches of it) does not sit snug against the windshield. I previously had Bosch ICONs and now I'm using the Michelins from Costco. Both did this. Does anyone else have this on their passenger wiper blade and is there any way to have it sit firmly against the windshield in the resting position?
HiHoeSilver
Away!
Chicago
Yes. This has been discussed on the NBS. I can't say first hand about NNBS. If you use a conventional frame wiper it will sit down. I like the beam style better, so I just stare at that one little spot it doesn't hit and swear at it for stress relief.
BG1988
I think this is typical with GM after mine stopped wiping correctly I RECYCLED them onto my broke friends car and they worked like new on his Chrysler 200 funny huh?
I swear they worked like new after putting it on his car tell the rubber fell off.... I replaced them every 2 years or so .
if I can get 2 uses of a single set of wipers that is pretty great.
St. Louis
My 2001 has ALWAYS been like that. My 2012 does too, but not as much
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
mine does it too, but not a big deal I'm driving and not sitting on the passenger side, my bigger issue is wipers not sticking to the window at higher speeds above about 80-85 standard wipers tend to lift off the window and essentially not work, I used to buy the bosch but now autozone makes a bosch knock-off for almost 1/2 the price and they will stay on the window above 80mph but they do start to lift off at about 100-110 somewhere around there.
It must really suck to have reduced visibility when driving in the rain above 100 MPH. Kinda makes me thankful for my relatively petty problems.
kbuskill
NE. FL.
At those speeds.... who needs wipers???
Actually I keep my washer fluid bottle filled with the Rain-X brand fluid and very seldom need the wipers, especially at highway speed.
I did recently replace my blades with the Rain-X silicone blades... they are doing a great job so far. A little pricey at $32 a piece but they did have a $10 rebate on them at Advance auto parts.
depends on how hard it's raining!, I will also swear by the goodyear eagle ls2's those tires will not loose there grip in the rain
Fosscore
Figured I would add a few pictures to your question since I have all 3 generations in my driveway.
There is a windscreen curvature change slightly over the years. NBS being the most curved and then it looks like it evolves into a less curve as it runs to the A pillar.
2019 Suburban - beam wipers - sits flush to the windscreen.
2013 Suburban - Champion traditional style wipers - lifts ever so slightly at the tip.
2006 Tahoe - Rain X beam style wipers - the most lift off on the passenger side.
13yukonNJ
13yukonNJ
New Jersey
Mine very closely resembles your 2006 Tahoe. Maybe it's more pronounced with the beam style wiper blades, since your 2013 (same year as mine) looks to have the old school wiper blades and they sit much closer to the window than mine. I'm glad I'm not the only one with this "problem" and now I see there's nothing to worry about.
Fosscore
Common problem. Yes the 2013 has the old school wipers.
Cyber Monday special for both, which were cheaper than one beam style at the time, so why not upgrade and the blades were toast.
The UV down here will kill that rubber pretty fast anyways. At this time of year it is only salt film and morning dew. The summer is a different story with the passing thunderstorms.
BG1988
get silicone wipers they last years and years
many vehicles, the windshield actually serves as part of the structural strength and integrity
Buford bubba
