Isaiah W
You stole those for $200! You could flip them and make almost $1000 if they are in great shape
I'm just going to keep them. Tires don't have much tread left, and weren't rotated well by previous owner, one has a small white strip where it's worn down. I'll probably run these Spring-Fall, then buy new tires before next winter.
Mikeh78
Idaho
Congrats on the new ride. We need some pics!
Here ya go.
Yeah. I wasn’t happy with the quotes I was getting in North Jersey so I took it to a body shop in TN where I grew up. He charged me half what the Jersey shops were quoting and ended doing a LOT more work than they could have done.
Did you drive it down? I thought a shop in NY was doing the work. Nice.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Finally got at that broken blower motor resistor. Can't get mad at it though, it was the original part! Not to mention it only took 15 minutes to pull the old one out and put the new one in... easy squeezy.
Bombsquad85
Northern VA
Swapped out the evap sensor on the intake manifold but I broke the vacuum line coming off it does anyone know what it's called or have a part number... it's the line I'm pointing to the evap sensor is what my middle finger knuckle is pointing at.
I have it JB Welded in place right now hopefully it holds until the new line can come in
Edit. Never mind found it and ordered new line
Sam Harris
This? https://www.rockauto.com/en/catalog...504408,exhaust+&+emission,vapor+canister,5180
Scottydoggs
NJ
id buy some vac line that fits over the the tube tight and use that to seal the two sides. less then a buck, done deal.
Bombsquad85
Northern VA
There isn't a way it broke on the connector near the bleeder valve
If you look t the picture the green cap is on a plastic piece that the tube connects to. Where the gray jb weld is is where it snapped on the connector. It's all 1 piece.
Here's a picture for reference
ASG-MikeS
