Front Reading Lamp Replacement
Buffdriver
How do I replace the bulb in the front reading light (overhead) on a 2005 Yukon Denali?
I couldn't get my fingers in there to pull the bulb out, I used pliars, worked great. Obviously don't squeeze hard or the bulb will shatter, just firm enough that it'll grip it, then pull down.
@Buffdriver If yours are like these, the map lights start at 0:21:
ya the round airplane lights are harder to do I changed them in my 03 silverado and the led's don't work real well in them either, the socket has 2 different voltages, one is lower voltage when you just open the door and regular 12v when you hit the button up top. so led's come on dim or not at all when just opening the door depending on what brand you go with.
Drewphil
