P0121,P2119 & U0100 Codes - Range AFM Unit
Plimbob
Des Moines Iowa
I have a 2007 Tahoe (265k miles) and I have the Range plug in unit installed to shut off AFM.
Lately, the engine light has been coming on after the vehicle has been shut off and started back up. If I remove the range unit and replace the light goes after after the unit cycles.
The codes are P0121 and U0100, I am wondering if the Range Unit is causing this due to the removal and re-inserting shutting down the engine light?
The P0121 & P2119 codes looks to be primarily throttle body related
The U0100 code says it is loss of communication with the EBCM.
Any one had any experience with this kind of issue?
Thanks,
Tim
CobraKing
How long did you have the Range AFM unit plugged in prior to these codes popping up?
Try running the vehicle for a week without the Range unit and see if you still get those codes.
P
Plimbob
Des Moines Iowa
I think the Range unit has been installed for over a year.
CobraKing
Try running the vehicle for a month without the Range unit. In the grand scheme of things it would be far cheaper for you to replace the Range AFM unit with a new one vs. diagnosing and repairing those fault codes.
P
Plimbob
Des Moines Iowa
Update -
I removed the Range Unit and the light went off. However, it has come back on with the Range unit removed. So I think I truly have something going on and I figure I will start with:
1. Replacing the TB - the vehicle has 265k on it and I have cleaned it twice over the last 150k. I assume it may be getting worn and proably past cleaning.
2. Try to determine what is triggering the U0100 code.
3. As an FYI for anyone who reads this with an older Range unit, they are offering a free firmware update if you send it in to them. I did take them up on it and sent it back for update the other day. They said it takes about 7-10 days for full turnaround shipping to and back considered.
buddyhotrod
Loss of ECBM
Never hurts to check fuses and give all of the wires under the hood a good look over with a flashlight.
Look for signs of rodents “poopoo” little feet marks, wires that may be laying on hot parts or rubbing or that have been chewed on.
Lately, the engine light has been coming on... The U0100 code says it is loss of communication with the EBCM.
How old is your battery and when was the last time the grounds and cables were checked for corrosion?
P
Plimbob
Des Moines Iowa
The battery is about 2 months old and I cleaned the terminals when I replaced.
I have also run an additional ground from the engine to the frame.
With regard to the TB, what are your thoughts regarding a replacement at this point (I have cleaned it twice in the last 150K, the unit has 265k on it) to try and remedy the P0121 & P2119 codes?
Thank for your help.
Tim
Drewphil
