Bombsquad85
Northern VA
Did you check the pins in the blower motor wire connector? I've heard of corroded or burnt pins there. It could be the control too; just because it lights up doesn't mean anything. Ebay has used ones for pretty cheap usually.
I'll pull the dash and check the controls. But the connections all look good I'm honestly at a loss. I emailed the seller of the resistor on Amazon to get a replacement under warranty so when I get that I'll try it out
HiHoeSilver
Away!
Chicago
Did you put a tester on the control side of the harness at the motor to verify voltage? That'd be my first move.
inmypassatlife
Who here has done the NNBS bumper on our NBS trucks? I have seen plenty of Silverados and HD's, but no Tahoe/Yukons...I am thinking of just going down that route instead of getting the ding in the lower rear quarter repaired. New and cool bumper covers that area
I don't want to do the step bumper and will more than likely run a black ready to paint bumper in the mean time....kinda like this
Thouse
Looks great. I will need to replace my bumper in the near future and like that look.
I do not like how his tired hang out 3 inches from his wheel wells but to each his own I guess. :emotions33:
PG01
Up here to the right
I was rear ended today, 40mph by a dodge ram. Happy I kept my bumper and tow hitch instead of run a rollpan, for this exact reason.
Small dent on lower rear quarter from the bumper. May take it for estimates and pocket the cash. Fix the bumper brackets and call it a day
Sorry bud, hope that frame ain’t tweaked.
dubyagee01
Installed some 9011 bulbs in the headlights. Casts light further and a bit whiter. Highs and lows with the six high mod.
brian.roberts.1293
Durham NC
Ok guys so I have a question. I have a 2004 Z71 suburban. I got a check tire sensor light in the DIC. I put my new tires on 6 months ago and the tire pressures and everything worked and I got my tire pressures on the display. Now since this check tire pressure monitor thing has come on now I cannot find the tire pressures at all on the display. Had the oil changed and an inspection yesterday. Asked them to check to tire sensors and he went around the truck and all of them beeped and the flashing light has never come on they this problem. But man I miss being able to see my tire pressures inside the truck. Any help? I've looked in the forum but found nothing.
brian.roberts.1293
Durham NC
Hey guys I need a hand. My front ac/heat stopped working. The control unit works (well display lights up and what not but the blower wont kick on.
I've replaced the resistor a couple months ago. But today I tried a new resistor as well as a new blower motor.
The fuse is good and all wire connections are solid. I'm at a complete loss right now. And winter is coming which means I need my defroster
Also I have a spare control for the front unit if you pay shipping I'll mail it to you to try it.
brian.roberts.1293
Durham NC
Have you tried the relearn procedure?
M3kanic
You may be able to turn it off/on in the dic or the batteries may have died.
brian.roberts.1293
Durham NC
No the gentlemen at the tire place that did the oil change relearned it per the instructions I found here. I watched and he had all four tires beep and then the tire light flashed I drove and it went away but still no tire pressure on my DIC and j have gone thru the menu ok n the steering wheel and it has no like on off menu I could find
2004 Z71 Suburban Green I have a few upgrades done.
chevync
North Carolina
I installed a Diablo i3 tuner for my Escalade. I installed the 93 octane tune. I've only put 10 miles on it, you could see the difference in the shifting between gears and also wot is better, I was up to 80 from 35 real quick. I'm going to do a few tweaks and see what else I can to the tune. Only mod is Airaid jr and drop in k&n. After christmas I'm doing exhaust with headers.
Massfloefi
Rebuilt steering gear from AC Delco installed. New Proforged inner/outer tie rods and Dorman exhaust manifold clamp installed.
Clamp worked like a champ. No more leaky exhaust ticking. Rebuilt Lares steering gear was installed and had to be pulled because it was defective. Work done by a mechanic.
brian.roberts.1293
Durham NC
Ok guys looking to have to buy some parts. My mechanic did the inspection and says my rear main seal is pretty bad. So I'm looking into replacing that. What other things should I do proactively while this is being done?
Korbin_A
