bigblue
I can get a smoking deal on a set of 26 inch wheels with kuhmo tires, my only concern is the tire size is 305/30/26. What size tires do you guys with 26s run?? Do you think this size tire would rub?
At stock height there should be minimal rubbing in the rear and at certain points throughout your turning the front wheels... incorrect backspacing could make it worse too. If you are lowered or will be lowering the truck expect the rubbing to worsen... however some cutting/massaging of the plastic fenderwell liner should help prevent or eliminate the issue. I also used a rubber mallet to slightly bend back the lowest spot of the rear fender just behind the front tires to prevent contact from being made there.
What kind of gas mileage do you get with the 26s?
I have somce 24s MOZ TOWER willing to trade and make some kind of a deal if you interested? let me know what you think ?
