I think I got a lemon
TahoeOn30s
TahoeOn30s
Key ignition wasn’t letting key out and rear driver wasn’t opening so back to the shop for me..figure it’s a key cylinder issue and actuator issue
TahoeOn30s
TahoeOn30s
Oh yeah and smoke was coming from hoses disconnecting off motor and leaking coolant
Miami-Dade
Moderator Supporting Member
Sorry to hear about all that. Knowing you that will all be under control in a short.
TahoeOn30s
TahoeOn30s
Refreshed old Alts to match build
TahoeOn30s
TahoeOn30s
Tahoe is bugging out now it’s running fine but every time I crank it a new sensor is going off alt abs and stabilitrack
massivespl
I'm not mean, I'm honest.
Michigan
Sounds like u have some wiring issues going on. I got a buddy with a 160db Tahoe and he don’t have no lights going on when he turns it up.
TahoeOn30s
TahoeOn30s
Did my research abs and stabilitrack just go off when driving n subpar conditions& the other light was going off just from the pcm not being able to control alt in oem spot..lights are going off anymore they shut themselves off
TahoeOn30s
TahoeOn30s
Well I got tune up and filter cleaned today took care of sensors turning lights on..it’s running much better.im thinking of retuning truck to idle higher since one light is saying low rpms at idle probably from having 3 stout alts bogging motor down.. I been seeing a few guys do it with good results so I’m highly considering it
Drewphil
