Brake Pedal
Danny3737
I sometimes get a very slight rebound in my brake pedal during moderate braking. I’m thinking it may have something to do with the hydro boost or anti-lock. It doesn’t pulse. Any ideas?
it could also (maybe) be a sign of warped rotors, if you are a diy type of person you could pull the rotors off and have them resurfaced, most places only charge $10-15 dollars if you take them to them.
Big Mama
Virginia
Have you changed your fluid lately? Air pocket? Also check your abs sensors and have the code read. They don’t always throw a light
Danny3737
Danny3737
Would you elaborate on what you mean by rebound?
The pedal gives a very quick/light kick back. It doesn’t do it very often. Maybe a couple of times a week
The rotors are pretty new and have zero run out. The fluid is only about a year old, maybe about 4K miles. Don’t have any codes.
For the most part the brakes work very well. I use E Coated rotors and Akebono pads.
mattbta
Frisco, TX
Have hydroboost? That kickback was a symptom a shop gave me when telling me my hydroboost needed replacing.
Danny3737
Danny3737
That’s what I think it is. It doesn’t happen enough to track it down. It’s not a big deal right now
When you do get it diagnosed be sure to have the power steering pump tested for adequate/consistent pressure at various RPMs. PS hoses in good shape?
BadDaddy2003
