Opinions on JBA headers
kbuskill
kbuskill
NE. FL.
I'm on the fence now. I've been watching some youtube vids on basic setups with longtubes and highflow mufflers and it might be too loud for me.
That is the other reason i like these... you maintain the factory cats and Y-pipe so its less expensive and the sound shouldn't really change that much. Slightly if any I would say.
Here is a video of these...
They sound kind of loud at the beginning of the video when on the dyno but if you listen to the truck when it driving on the road it's fairly tame compared to some.
Onebad1983
Resident Country Dumbass
I saw where JBA was a PerTronix company.
Further research...
PerTronix website says...
Under the brand names Patriot Exhaust, Smithy mufflers, and VeraFlow mufflers, PerTronix supplies the Street Rod and Muscle Car markets with headers, mufflers, side pipes and do-it-yourself header components primarily through performance warehouse distributors. Doug’s Headers includes many header applications for muscle cars, SUVS, trucks and motorhomes.
http://pertronix.com/prod/ex/default.aspx
Not sure what all that means but thought I would share.
Our show/performance car (2005 Magnum R/T AWD) has a full jba exhaust system with JBA headers, performance cats (not sure if JBA or not) and a full JBA cat back system and it sounds amazing. not on a 5.3 but just would toss in my opinion. We haven't had any problems with it and right after we bought it my dad put it on the lift and did a very thorough inspection and said it was pretty much perfect
GranPrix
That sounds really good. And those #s are just the shorty's, stock cats and cat-back.
kbuskill
kbuskill
NE. FL.
That is correct. They don't even mention reprogramming the ECU which makes me wonder how much more power might be attained by adding a proper tune with these.
Either way I think I would like to give them a shot... just gotta find the extra money laying around somewhere... lol
I keep reading about clearance issues with longtubes and the y-pipe replacement. Why is that?
Motor mount condition making every truck different, loose header and/or Y-pipe build tolerances, loose stock exhaust build and mounting tolerances, modified exhausts shifting the stock pipe one way or the other... There are lots of reasons.
Other than the front prop shaft (4WD) clearance issues, I think the clearance/alignment problem is mainly where the outlet of the Y-pipe meets the stock inlet to the rest of the system. As far as I'm concerned, it's just a matter of either pulling one pipe and pushing the other or adding in an offset piece. Maybe most people expect it to bolt in EXACTLY as the original came out. Considering all the variables, it's very difficult to make a one-design-perfectly-fits-all Y-pipe.
BTW, what's an Italian throttle mod?
Classic!
You're only the second one to ask about that. Ken pretty much spelled it out. The forum's resident Italian mob buffoon, @Galante, came up with a "performance mod" that increases throttle response. It works only on those vehicles that have the adjustable pedals... You can figure out the rest. lol
Drewskiii
I run the texas-speed longtube on my yukon, i have no issues at all, hopefully soon will get it dyno tuned, street tuned at the moment.. just my .02c opinion and im on a 2/4 drop
01FormulaTA
As far as the JBAs go, IMO I wouldnt bother with shorty headers...the gains would be minimal, and most likely unnoticeable on a NA vehicle....
Ive used ARH and Kooks on multiple vehicles and never had an issue with leaks or cracking...some on here have had great success with Texas Speed headers but be aware they are just rebranded Chinese products...
Ultimately for such a heavy vehicle like the Suburban I wouldn't recommend longtubes either as all you will be doing is shifting the power band up, IE the truck will FEEL slower under normal driving conditions...especially with the 5.3
If you are wanting an increase in SOTP I think changing out your rear-end to a 3.73 or 4.10 would be a much more effective mod
Lastly, if you are just dead set on getting some headers I think it would best if you could find someone with a NNBS Tahoe or Burb 5.3 with headers and go for a ride or better yet test drive yourself so you can get a feel what the end result will be
Oh and for the best results a good tune is a must, even a tune on a stock 5.3 can make a noticeable difference...
GranPrix
Yea I'm not going to bother. $$$ spent vs gains isn't worth it to me. Slapping on an AP muffler Magnaflow copy for $49 shipped and calling it a day.
kbuskill
kbuskill
NE. FL.
I understand what your saying about shifting the power band up in the RPM range which is why I liked how these shortys actually shifted it lower in the RPM range.
My Burb already has 3:73 gears and a custom tune which is why I was looking at these.
Thanks for the input and keep it coming.
kbuskill
kbuskill
NE. FL.
I understand that people always say long tubes or it's not worth the effort but when I see decent improvement on the dyno from an independent tester not affiliated with the manufacturer I tend to believe it more than if it were coming from the seller/manufacturer.
Also the reviews I have read on a lot of different sites from people that are "verified purchasers" seem to indicate that there is indeed an increase in power in the lower RPM range... which again is where you would want/need it with a big heavy truck.
I may have to be the guinea pig for these eventually if I can ever find the money.
97audia4
Anything is better than my rotting stock headers. After winter I am going to forced to get a set of shorty headers, I would rather go after market quality set and not worry about a stud or manifold warping. I will be doing a lot of towing next summer long distance and want peace of mind.
Ilikemtb999
Denver
I’ve got some long tube headers I’ll be ceramic coating next week and hopefully getting on soon. I’ll probably get a tune not long after.
If there’s gains to be had with shorties and the install is easier then why not?
when I had them on nbs there wasn't much difference, maybe a slight bit louder under the hood but otherwise not much difference at all really
kbuskill
kbuskill
NE. FL.
Did you have JBAs or just shortys in general???
Edit... guess I should pay more attention... I just noticed you had quoted someone else... lol
the patriots shortys, the longtubes are illegal in cali, although I don't know how stickler they are on that since all they do now is plug into the computer, look at your cats and send you down the road in less than 5 minutes.
enigmaspeed27
