Black Denali Grille
Hoganator
I want to blacken the chrome honeycomb grille on a 2016 Yukon Denali but leave the outside surround chrome. I'm going for the look on the pic attached. Has anyone done this and what method did you use to do it?
bamachem
I did the whole thing with plastidip to see if I liked the look. Now I'm going back and peeling the plastidip off to replace it all with satin black single stage paint for durability.
If you don't think you'll reget it, use paint.
If you use plastidip, no need to mask anything off, just spray it and peel off the excess. For paint, you'll have to mask everything off and put some cardboard behind the grille to keep overspray off the radiator/condenser. Removing the grille is a pain.
CMoore711
I know this off topic; Did you plastidip the chrome trim on your retractable steps as well? If so how’s that holding up? If not, how’d you get rid of the chrome trim there?
HunterWhiteBus
Has anyone tried to vinyl wrap their Denali grill instead?
fiatdale
Houstons Best
Houston
Take the grille out and bring to a body shop. It’ll be done right and will last. If you’re near Houston, I’ll do it for you.
Hoganator
Hoganator
Up here in DFW unfortunately. Know anyone up this way? Thanks
bamachem
I tried plastidip. Lasted about a week before it started to peel at the wear spots from getting in/out. Peeled that off and painted them. It seems to be holding up great now.
I also had plastidip "wear" issues at the door handles. It just doesn't stand up to the use. I had to mask everything off and paint.
umpuck
I love the tires on there! Have you noticed any change in ride quality?
cireallin
Looks great! Did you end up trimming your front fascia or install the PPV version for the Tahoe?
Drewphil
