Speaker Wine?
LTZboy
I haven't had my 2007 tahoe but for a few months. But I have noticed a wine in speakers especially with the sound turned all the way down. I know it is normally a wire that isn't shielded properly. Has anyone else had this issue with the factory Nav and Bose system?
TX LTZHoe 07
Weatherford, TX
Yes, I have this problem. This was one of the issues that I was going to discuss with my service department.
It has done it since I have owned the vehicle (5 months)
blaqout
King Yukon
Indianapolis
+1 I have the same issue. I can only hear it when the radio is either off or very low.
chris.
Some call it alternator whine, usually a signal wire (rca) ran closely to a power wire, or could be a loose/bad ground. Check that and also if you have aftermarket amp you could add a ground loop isolater(sp?) and that should take care of it, if its all factory and in the actual speakers and not the sub...then i am of no use. Good Luck
L
LTZboy
I am going to add it to the list when I take it in for service since it is still covered under the certified warranty. I'll let everyone know what they say.
TX LTZHoe 07
Weatherford, TX
dealership says they may have to replace the stereo. :( Will update whenever they finish.
On a high note, they gave me an Equinox as a loaner. Its no Tahoe in size, but its a pretty slick little vehicle. The fuel mileage is nice.
L
LTZboy
Nice maybe they could replace it with the newer head unit with the ipod connection and XM traffic :)
Let me know if that is what they do, since mine will probably need the same thing done.
tx07tahoe
Houston,Tx
Mine a recently started the same wine. Im the original owner and only just started hearing it.
TX LTZHoe 07
Weatherford, TX
Oddly enough (or maybe it's not), they replaced the alternator to fix the problem. Said there was a bad diode in the alternator even though I have not had any charging issues.
Anyway, it seems to have fixed the problem.
L
LTZboy
The alternator might be the case with mine too. I have noticed somedays the gauge goes down to about 8-9volts and then it shoots up to 14 volts kinda has a mind of its own, but never throws a check light to alert there an issue.
Thumper8302
OKC, OK
mine does that as well... just bought my 01 yukon less than a week ago.. when i stop at a stop sign or a stop light ill notice my voltage and rpms drop... im not used to the vortecs yet.... been drivin a 90 suburban the last 5 years... ill prolly have the alternator tested here in a few days..... if thats the case im definately gonna add a bigger alternator when i swap my stereo over...
cmorris
KY
09 denali xl with the same problem
I just purchased an 09 xl denali and have the same problem with factory nav unit?????
ASUalum
Me too! Sounds like a real high pitch that only a dog would here lol (I guess I'm a dog because I can definitely hear it). Sad thing is I just picked it up today. :shocked:
I'm going to take it to the dealer and have them check it out (I'll mention the alternator).
cmorris
KY
Let me know what they say if you dont mind, I am going next week as well!!!!
thanks
Derf
My 2008 does not have the wine. I can hear very low music in the back ground when the radio is off and the NAV is on. :shocked:
blaqout
King Yukon
Indianapolis
When I installed my aftermarket radio, my speaker whine went away. So, I figure it was either the factory stereo or a bad ground (loop) in my Overhead DVD which I re-routed the ground and 12v to the 12v ACC behind the new radio.
07Denali
Any whine like that is likely an alternator problem in a newer (07+) truck. That diode that goes bad causes a barely audible whine or hum in the audio system. I have had it happen in several GM vehicles that I have owned.
L
LTZboy
I finally got a chance to bring mine in for service and they said they could not duplicate the problem. I told them to keep the car until it was fixed. I guess I need to tell them to check the alternator. Anyone else have a hard time getting the techs to hear the whine?
preston
Humble, TX
I haven't had mine looked at yet, but I have a speaker whine only when in CD mode. Thought that was kind of weird.
cmorris
KY
I had mine checked and they replaced the alternator, the whine is very low and you really have to listen for it but it is better.
c
General Fodder
