PG01
Up here to the right
They're in a pile in my garage. Duh.
Don’t ever bust my chops again.....lmao.... i think you have more parts in ‘storage’ than i do at this point.....lol
The video is upside down, I know, but you get the gist.
See photo below with yellow arrow for where I am hearing the noise.
AC clutch, idler puller, bearings, belt?
A/C on makes the noise.
A/C off some noise, but not as noticeable. Sometimes gets a bit quieter after more driving. Quite pronounced at start up. But always clicking.
A\C blows cold and strong.
Yellow arrow is where noise is most noticeable.
@Fosscore when was last a/c belt change? I’d slap a belt on but while its off spin all pulleys that you can by hand just to see if anything jumps out at you, then put new belt on... cheapest, easiest and you’re gonna end up doing it anyway. Idk..... just my .02. Good luck
Scottydoggs
NJ
did some flood running today, 1/2 way through it im like damn that post about the water in the filter, i was in like 2 foot of water lol
no issues other then its quite floaty feeling. im guessing its the gas tank lifting it up.
06JET
Wisconsin
Got my new AC condenser today. Waiting on the belt and steering fluid cooler.
06JET
Wisconsin
Does that work on painted surfaces also?
Not really. It has made some of the old paint on the frame bubble but does not eat it off.
It is a slow go but it is working. I used the 4" grinder with a wire wheel on what I could get to today to speed up the process. We will see.
Fosscore
@Fosscore when was last a/c belt change? I’d slap a belt on but while its off spin all pulleys that you can by hand just to see if anything jumps out at you, then put new belt on... cheapest, easiest and you’re gonna end up doing it anyway. Idk..... just my .02. Good luck[/QUOTE]
Ok. Serp and AC belt at same time or just AC belt?
Take a spray bottle with water and spray on certain parts. Like the AC belt and see if it changes the sound.
Might give that a go as well.
Thx input guys.
Would like to accomplish this one myself, but TBH I do not recall last belt change without digging through my binder.
I have not had to deal with a belt change myself, but wouldn’t mind giving it a go. I can YouTube it, but you guys have any tips? Thx.
Edit: watched YouTube video, but got sidetracked with this...
HiHoeSilver
Away!
Chicago
Not 'storage'. In 'queue'.
Fosscore
All Rockauto.
@HiHoeSilver
Did you go with all AC Delco parts on Rock Auto? Standard or HD stuff if it was available? For example the AC Delco AC belt has a few different levels and prices as does the tensioner. $20 difference between standard and OEM. Thx man.
HiHoeSilver
Away!
Chicago
@HiHoeSilver
Here's what I did. All Acdelco OE. (except the AC belt. I had gotten a Gates fleet runner on sale). Overkill on a 12 year old truck? Maybe. I think it was @Tonyrodz that had the Acdelco PRO idler go bad pretty quick....
You're stuff might be different than mine, yours is 4.8, right?
PG01
Thx input guys.
View attachment 207587[/QUOTE]
Do a/c first, To narrow it down
Fosscore
Yes 4.8 and the AC never gets a break, even though the truck is not my DD. I just saw those fleet runner and more $$ parts and always like to use OEM if can, but wanted to see what you used. Thx for the info.
Will go that way first then. Thx.
PG01
4 bolts to drop the plastic splash shield and you’ll have tons of room to work. Good luck
HiHoeSilver
Away!
Chicago
I figured a good old refresh was in order for mine up here in rust land. Agree with Pete. My noise was definitely the AC tensioner. Quieted right down when I shot it with aerokroil.
Fosscore
Just curious what size alternator you have?
The RPO from my build sheet for the 4.8 is
KW1 GENERATOR,160 AMP which I looked up to select the correct belt for that alternator (provided it was not changed before I got it of course).
I think my 4.8 had the 130 amp--nice. I upgraded to the 160 amp, then had to get a slightly larger belt.
Hey, hey--don't drag me into this!
HiHoeSilver
Away!
Chicago
KW1, 160.
Escalade2007
