I’d make sure they are all there first could be something as easy as that I had all the stick on weights on the driver front wheel come off on my previous set of rims and it caused a nice shake think it started around 25ish
I'll check it out when I swap out the rims.
Fosscore
Nope, 17's. These Jersey roads suck.
Maybe me too. 16s FTW! Winter wheels time. :adminpower::insane:
06JET
Wisconsin
Changed from zip ties to rubber coated clamps for my brake lines and brake sensor cables. Pulled out the sensors and cleaned them so hopefully the anti lock will quit kicking in at 5 mph when I am parking. I've almost hit other trucks in the parking space ahead of me because of the anti lock kicking in.
95escahoe
View attachment 207247 View attachment 207248
That’s a pretty good idea what sized clamps did you use and what about the screws or bolts to hold them on?
06JET
Wisconsin
Just got this kit from Harbor Freight and used what worked. I had to use a bigger one in the middle of the a-arm so I could bend it down towards the bottom of the arm. Used factory holes.
wwiizz
