915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
DELETED THE USELESS ON-STAR ANTENNA ON THE REAR QUARTER GLASS. JUST THAT LITTLE THING MAKES THE TRUCK LOOK DIFFERENT IN MY OPINION.
915_Tahoe
HELL PASO, TX
JUST REPLACED THE FRONT DRIVER/PASSENGER SIDE ARM RESTS WITH SOME USED BUT IN GREAT SHAPE ONES. THE OLD ONES WHERE UNGLUING FROM THE BOTTOM.
Keviebear86
Well, no better time than now to install this, apparently I over torqued the oem bolt and it worked it's way out. What I thought was the cheap torque wrench indicating it was right was the bolt breaking lol
This came in the mail a day late, but glad it sprung a leak in my office parking lot not on the road
full
Where do you find that billet piece? Mine is leaking as well.
TheAutumnWind
Gf had a big scare today. It's been raining all day here, and she doesn't like how the 22's ride in the rain, while getting on the on ramp for the pkwy the rear broke loose on the Hoe and she spun out, completely around. She was facing oncoming traffic, the wrong way. I wasn't with her, but she said she doesn't know how no one hit her. Luckily she was able to pull onto the shoulder, the correct way. I came and she drove my van home, while I drove the Hoe home. Needless to say she wants the 17's back on. At highway speeds, in the rain-it did feel a little loose. Took the back roads home and it felt fine. Luckily there wasn't any damage to her or the Hoe. Funny, she said she hit the curb, but there wasn't any shaking or anything else that I saw or felt.
Glad to hear everyone is ok.
I cant get the Esky to break loose if My life depended on it.
Not sure what 22's would do to make it more squirrelly in the rain. My 20's sure dont seem any different then my 17's on my old denali.
Must just be the tires. Running a lot of tire pressure?
Running 36 all around. On the highway today and I noticed more shaking in the frontend, more then usual. I saw where she wiped out today and she def jumped a small curb. Chewed up some grass and mud. Just by looking at the grass and mud I'd think there'd be alot of damage--but none that I can see. I think, if anything, maybe the rims got bent a little on the inside beads.
95escahoe
What kind of wheel weights do you use? If it’s the stick on ones they are known to come off
95escahoe
Had my local mechanic drain and refill the front diff, transfer case & rear diff along with replacing the fuse box in the dash of the driver side (it was causing a few different electrical issues)
95escahoe
Yup, stick on type.
I’d make sure they are all there first could be something as easy as that I had all the stick on weights on the driver front wheel come off on my previous set of rims and it caused a nice shake think it started around 25ish
