2004 Suburban 1500 towing issues: Engine or gears?
Martinjmpr
Littleton, Co
(Crossposed from Expedition Portal):
Closing in on 3 years now of using the 2004 Suburban (1500, LT, 5.3, 4x4, 4L60, 3.73 gears) as our primary tow vehicle. Previously we had a 2,000lb T@B trailer but in January we upgraded to a ~ 3500lb R-Pod 179.
The "issue" I'm having is when climbing steep, high passes (here in CO you can't get from the Front Range cities to the mountains without crossing at least an 11,000' pass.)
As I slow down, of course the 4 speed 4L60 drops into a lower gear. 2nd gear is actually pretty good for climbing and I can typically keep up with traffic at around 50 mph even in 2nd. But as the hill gets higher, the weight bogs the rig down and speed drops. When it drops below about 35, the truck wants to kick the transmission down a 1st gear - which of course makes the engine spin around 4500 rpm (screaming.) That typically only lasts a few seconds before it shifts up to 2nd but then it bogs down again and drops back down to 1st. This sometimes happens 5 - 10 times while ascending a steep pass (think Eisenhower Tunnel or Berthoud Pass, for those familiar with them.)
When we had the T@B this never happened, we could stay in 2nd gear the whole time. But our trailer weight has nearly doubled and I can really feel it when climbing those steep passes.
Not only is it a bit of a shock to feel the truck dropping down into 1st gear, I'm worried about what those hard shifts and high RPMs will do to my transmission and engine (transmission was rebuilt 2 years ago @ 150,000 miles and has worked fine since then.)
So my question for the GMT800 Hive Mind is this: If my goal is to be able to ascend passes more easily, should I be looking at doing something to boost power/torque or should I be looking at lower gearing?
I'm not looking to spend a ton of money and I don't want to put too much stress on an already middle-aged drivetrain (170k) so I don't think turbo/supercharging would be a good idea for me. Are there less "radical" power mods that would boost the power of the engine?
EDITED TO ADD: I'm not a huge fan of things like Cold Air Intakes or air box removal - I'm just skeptical that they really improve power. Ditto for "reprogramming" the computer, as I think that assumes that the "tuners" know more about the engine than, you know, the people who BUILT it. Adding power and sacrificing reliability or utility would pretty much defeat the purpose of what I'm trying to do here.
Or would it be a better idea to simply change the gearing to, say, 4.11? And if I was to do this, what would I be looking at, cost-wise, to replace the front and rear gear sets (and ideally retaining the G80 locker in the rear?)
Anyone else had this issue with a 1500 'Burb towing? (If I'd known we were going to be getting a heavy trailer like this I might have held out for a 2500 but that's 20/20 hindsight at this point.)
Thanks in advance!
Scottydoggs
NJ
4.10's might do the trick, but your gonna have to trust a tuner to change the gear in the tune or your speed o will be off by a bit. easy grand for both axles if not more id think.
and tuning unlocks power/performance the factory robs you of.
i had 2500 hd pick up with 4.10 gears, and the 6.0 that back in 03 had only about 300 hp, and a 80le trans. i used to tow my 4,000 lb boat all over the place. id forget it was back there some times, pulled it like nothing.
had a 97 3500 with the last of the 350's, had a tb injection, less then 300 hp i want to say 270. same gears, also pulled that boat like it was nothing.
SnowDrifter
Sasquatch Country
That's definitely odd. I've towed a 6k trailer through the cascade mountains(3000-4000ft depending which route I go) going 60. Had to do it in second, 5.3 didn't have enough oomph to do it in third. It's clear it's not a tow rig, but it wasn't complaining and still had some power to give.
I just poked at some math. at 11 thousand feet, you're only at 66% of normal air pressure. Do you have difficulties only at the higher altitude? Or is it like that even when ascending a grade starting from sea level or close to?
Martinjmpr
Martinjmpr
Littleton, Co
Didn't EFI basically eliminate the old "no power at high altitude" issues cars used to have? I thought the oxygen sensor in the engine leaned out the fuel mixture to allow for more air (thus more oxygen) at altitude?
Haven't noticed any difference at lower altitudes but to be honest I live in Denver and we go to the mountains almost every weekend, so going to a LOWER altitude isn't something I do very often. ;)
Scottydoggs
NJ
being at that elevation will for sure hurt your power.
i know a guy from out west in the mountains (6,000 feet) from anther site. we both have the same car pretty much, only hes got more mods then i do, hes got a cam and heads on his, and on paper he should kick my ass, yet i run a second faster in the 1/8 mile then he does. im at sea level pretty much, iirc my track is 1000 foot up or so. but i live literally at sea level lol
thin air is like breathing through a straw for a engine really.
SnowDrifter
Sasquatch Country
Less air is less oxygen. Can't add as much fuel. There's no way around physics
SnowDrifter
Sasquatch Country
Imagine: You're basically running with a brick under your throttle. As far as your engine is concerned, that's exactly what's happening
SnowDrifter
Sasquatch Country
Thinking about it more: This would be an ideal use case for a turbo. As a matter of fact, this use case is exactly why forced induction was invented. It was originally for aviation so the planes could overcome the thin air at altitude. An altitude correcting tune would allow your vehicle to make the designed power level at all altitudes. Zero boost at sea level, and increasing in proportion to a decrease in atmospheric pressure. Now whether or not the cost/reward ratio is appropriate is a decision you need to wait.
You could accomplish something similar with a supercharger, but I think you'd run into issues with boosting beyond stock at lower elevations
Scottydoggs
NJ
not to piss in your cheerios, but the guy i know out west is supercharged, as well as i am. (on the 3800 engines) you still cant make the same power at elevation, the thin air kills everything. you cant make up for lack of air.
whats really nuts is he cant get over 18º wot timing, hes been on e85, e85 with meth injection, still cant go any faster. where im on 93 gas rockers, diy ported heads a fsic and meth, running 21º wot kr free. where hes got kr at 18º. he tends to run about 16 most of the time but turns it up at the track to play with it. and still has kr on the street with 16. he also had a intercooler that did 100% nothing to help him. so i bought it off him. his track times stayed the same, where mine picked up. and im actually able to run a smaller pulley on the sc then he is. im on a 2.8 he could never get past a 3.2.
being you cant get all the timing you'd like to have up there, when you come down to lower elevation you wont blow up, cause your timing is already lower then it should be. having a tuner would be nice if you took trips up and down the mountain for any amount of time. a flash takes 30 seconds, lap tops take up no space really.
where adding forced induction will help over stock. its still not 100% the power you'd get at a lower elevation.
Scottydoggs
NJ
Local guy here, experiencing the same with my '04 5.3 Flex Fuel, 3.73 gearing. When I towed (always in Tow Mode) my popup -- 3100 lbs gross but never loaded to that -- the high mountain passes weren't too much of a problem, although I've not really been happy with the throttle response and shift points even when not towing. They're too far apart and it seems like one has to mash the pedal to get a downshift before low RPMs become an issue. Then, of course, the high RPMs and screaming begins. I don't think 4K RPM is a problem, and I think that's a good spot in the power band if what I'm reading is correct.
I sold the Pup, though, and recently towed a TT (Viking FQ17, IIRC) that has a gross weight similar to yours. The extra weight amplified the issues with power loss at high altitudes.
I plan to get a tune to improve things, especially throttle response and shift points. Part of the factory tune on these is to maximize fuel mileage so better response suffers from that.
For the time being I've learned to slow down a bit and not expect to keep up with the cars.
SnowDrifter
Sasquatch Country
Don't judge me for my taste in cheerios
Nah but on the real... I wonder what's different about the air composition at altitude then, if simply pressurizing it to sea level doesn't yield the expected power improvement
Scottydoggs
NJ
its less air over all. at elevation a engine is like you trying to breath through a straw while running as fast as you can.
why people get out of breath so easy when they travel up so high too.
also why fighters train at elevation, they get used to working out there when they come back down they can now take more oxygen to their muscles giving them a larger gas tank so to say. or insane cardio.
Air contains 20.9% oxygen at all altitudes; lower air pressure at high altitude makes it feel like there is a lower percentage of oxygen. As @Scottydoggs said, less (thinner) air overall so less oxygen.
Here’s a chart of “effective” oxygen % at various altitudes:
https://www.higherpeak.com/altitudechart.html
At 10,000 ft. in elevation one would experience around 30% less effective oxygen (than at sea level) in the reduced air pressure. Gotta have the oxygen to burn the fuel. It's why high altitude athletes acclimatize whenever possible.
Josh61513
4.10 Gears would help keep you in 2nd, but would decrease your speed in 2nd gear proportionally (about 10%) for a given engine RPM. And especially being 4x4 (2 axles) that’s probably cost prohibitive especially being a higher mileage truck.
Unfortunately there’s not a lot of low hanging fruit here without spending more than it’s worth.
Decrease your drag if you can-run your truck and trailer tires at their max pressure. Make sure your engine and trans are running as good as they can-clean air filter, synthetic engine oil and fresh Dexron in the transmission.
Keep your weight in the truck and trailer to a minimum.
A tuner may help a little but I doubt it will be enough to keep you in 2nd gear.
Other than that unfortunately I think your most logical move is to run the truck as-is until you can trade for a same year Suburban with 4.10 gears, upgrade to a 6L powered Denali, upgrade to a newer 07+ Suburban (with 4.10 final gears of course!) where the 5.3L got more power, or upgrade to a 2010+ with the 6 speed transmission and max tow package. Amy of those would give you noticeably better towing performance. Dumping a bunch of money into your current rig may leave you disappointed with a lighter wallet.
https://www.trailerlife.com/wp-content/uploads/2012/01/Trailer-Life-Towing-Guide-2004.pdf
BadDaddy2003
