Can't find what rear springs to get
xDan
I can't seem to find an answer to the correct rear springs to get...
2003 Tahoe 4WD LS with nivomat premium ride suspension but I'm converting to a standard shock and spring setup. I installed 4 monroe reflex shocks. I have seen the bilstein conversion springs but people are saying they have too light of a spring rate. Right now with the nivomat shocks removed, the rear end squat is massive and 100 lbs of cargo in the back makes the rear drop way too much. On bumpy roads the rear seems to be floating around all over the place. I am looking at carid.com and found two spring sets:
16" free length 1040lb load rating spring (45H2165) and
17.2" free length 1300lb load rating spring (45H2164).
Both have an installed height of 11.5". No idea which one of those, if either I should get.
HiHoeSilver
Away!
Chicago
I would look at the moog z71 springs I think.
#81069
Big Mama
Virginia
Have you checked with NorCal SS on here? I don’t think there’s a suspension set up they don’t have.
xDan
xDan
#81069
Yea z71 should be a good option. The problem with that is, on the SUV's, a z71 can also have the zw7 option according to some.
Sounds expensive. I'll see what they have though.
What would be great is if all springs sold required spring rates listed at full compression and full installed extension.
HiHoeSilver
Away!
Chicago
The part I listed is not for zw7. They will also provide between 0.5-1.5" of lift over your stock ride height when paired with a Bilstein 5100. Should help with your towing.
xDan
xDan
Perfect... Because I already removed the ZW7 nivomat shocks. Up here I couldn't get those Moog springs for a good price, I did find ac delco 45H2164. Your suggestion helped me decide to get the heavier spring rate, used in 2wd HD suspension and the Z71 4WD.
For Nivomat shocks with ZW7, does that include the Auto Level RPO code too?
Just curious as I have ZW7 and regular shocks.
xDan
xDan
Just nivomats in the back. Fronts are regular. No electronic shocks.
Rear spring code is YD6. I don't see any other suspension codes.. Not sure what 6XK &7XK are.
I have YD6 too. 6XK and 7XK are the specific spring codes, left and right. Mine happen to be 6RS and 7RS. No Nivomats.
Dan, what did you end up doing and where did you get the specs for these springs?
I know now, that my stock rear springs are the 25783733/45H2164.
@Snowracer1000
CKendrick
