Remove springs from struts help
tgui
I have a nice spring compressor but not sure how much of the top of the strut comes off and what nuts to turn once the spring is compressed.
Any help or links?
T
tgui
It looks like one long nut on top of a short wider nut?
I have another car to get to work just feeling like an idiot.
T
tgui
Duhh, 2 deep sockets right? Sorry for the train of thought thread!
Pretty sure that topmost "nut" is the connector for the Autoride and there should be a larger nut inside that hole that is threaded on the shock's shaft.
have to remove the bolts, here is video on how to do it if you happen to have the nice $1400 spring compressor lol, but same procedure if your just using a regular spring compressor
kbuskill
NE. FL.
Not sure if you are reusing the struts but on the autoride struts if you let the shaft spin while you are loosening or tightening the nut the struts will be ruined.
The long "nut" on top is indeed the connector for the auto ride.
The nut below that... the one that is counter sunk into the top plate, is the one that needs to be removed to disassemble the struts and remove the spring.
I used a pass through socket set and a pair of vise grips on the tip of the shaft :eek:
Something like these...
View attachment 206617 View attachment 206618
I knew there was a caveat! I guess they say to grip the shaft of the old one with Visegrips since you're replacing that strut anyway. But if you gotta return it as a core to get money back, you're gonna have to do it the correct way and invest or borrow a pass-through socket which you'll need anyway to install the new one.
Knowing me, I'll buy a socket from Hazard Fraught, slice the back off of it and weld a bar to it for turning leverage. Although, I'm ditching Autoride with the Belltech struts so whatevs.
T
tgui
Very neat.
Just so I can learn why does spinning the shaft hurt autoride struts?
kbuskill
NE. FL.
Yeah the pass thru sockets are just about a must... or cut and weld as you mentioned... because of the nut sitting below the surrounding metal.
I also went to the Belltech drop stuts... I wish they were a little stiffer but they are not bad... not sure if they would be any stiffer with less drop... ie more pre tension on the spring.
kbuskill
NE. FL.
Very neat.
I have no idea... that is just what I remember reading... I would assume there is something inside that gets damaged and won't allow the autoride to function any longer.
T
tgui
***** apart now. Not like I anticipated but it happened. The spring compressor worked well. The 2nd nut on the strut was fairly welded in place. I actually had to grind a place to clamp to remove it. Also the strut broke in half. Yeah....
Broken apart
Ground place to grasp
Ready to twist with fancy sockets
All in pieces
justinakay79
