@Rocketman I thought you would have had that installed by now.
Remember, you need to add an additional relay in order to be able to connect with that AC compressor wire. The blue trigger wire on the OEM harness is the AC trigger wire, and it's triggered by a negative. You just need the additional relay to change the positive trigger from your AC compressor wire to send a negative trigger to that blue wire. I have had mine wired up like that since about early 2011 and it's held up just fine in these brutal Louisiana summers.
I was trying to see if my upgraded ls1fans harness would be ok. I have my answer lol. I'm aware about the extra relay. I have the relay and I can find your write-up on it in the Tech section. Thanks.
ScottyBoy
Shreveport, La
You should take a few pictures of the all the melting and make a thread on here and the other sites. This is the reason why people want OEM harnesses now. And I can't even keep up with the demand. Every time I find one at a salvage yard, I grab it and refurbish it and it's sold within a week usually.
Keviebear86
Love that wheel/tire combo. What size wheels and tires?
20x10 Hostile Sprockets -19mm offset
275/60R20 Tires
The tires are just junk used ones until I decide on what to put on it. I'm torn right now, I work at a Firestone independently owned shop so I'm either looking at the Firestone Destination A/T or the Bridgestone Dueler Alenza Plus. I won't be doing any offroad driving, just highway and in town. I like the look of the A/T but the performance of the Alenza is unparalleled...like I said...torn lol
Massfloefi
Replaced crossmember bushings last weekend. It's a real treat in the driveway with minimal workspace. I'd say to pass on doing the replacement yourself if you have a mechanic that will charge you max 2 hours labor. Most around me wanted 4 hours to replace.
Bombsquad85
Northern VA
Another busy day... luckily it went smooth(er) compared to yesterday.
The camber bolts (1 on each side) gave me a huge problem and were rusted in. I had to break out some muscle today to break them free. That took the longest part of everything. I'm just happy I prepared for it and ordered new moog camber bolts.
Tierods were cake and once the old UCAs were out the new ones went in flawlessly.
The front end is insanely tight. I'm going to try to schedule an alignment tomorrow.
Next up is to attempt to finish the free travel mod then fun stuff like repainting the hood
20180801_153851.jpg 20180801_153857.jpg 20180801_153801.jpg 20180801_153925.jpg 20180801_153931.jpg
brian.roberts.1293
Durham NC
View attachment 204486 View attachment 204487 View attachment 204488 View attachment 204489 View attachment 204490
Dang brother that front end is looking awesome. While I was having the muffler welded in I took a look at a lot of the front end bushings and none of them looked to bad. Thank goodness. Great looking job man.
Sent from my SM-G965U using Tapatalk
Bombsquad85
Northern VA
Thanks man. It was a ton of work. But the front end is solid now and responds great. I have an appointment for an alignment tomorrow as well.
Pilot
Bloomfield, NJ * Lewes Beach, DE * Buenos Aires
Driving to Newark airport, suddenly I start hearing a horrible clanging/grinding sound on the highway. It seems to stop when I let off the gas. I end up driving the rest of the way to the airport on the HWY at 20mph (it was NOT fun, but there was no way in hell I was missing my flight to Iceland). Make it to the airport, leave it in economy parking and catch my flight. Once I returned I had it towed to a shop in Brooklyn. It's hard to say what went bad first, but by the time the shop looked at it, the transmission was so mangled they couldn't even rebuild it. SO to the tune of $3300 I had a new transmission put in. Had them fix the AC while they were at it (thank god).
So I'm back up and running. Probably going to focus on paint/body work and 6 piston brakes next. These stock brakes aren't really can't handle these oversize wheels and tires.
Bombsquad85
Northern VA
Dang. That sucks
95escahoe
How do you like the Belltech shocks? I’m debating those or Bilstein 4600’s had the Belltech silver shocks on my OBS with a mild drop rode good
$3300?? Damn!
Massfloefi
Engine light went on the other day. Blue Driver picked up code P0135. One of the upstream O2 sensors needed replacing. Mechanic needed to heat it up and it still took all the threads out with it. Had to rethread but it is fixed now. Gonna be one hell of a truck after all these repairs.
Bombsquad85
Northern VA
It's not bad. I only have blown autoride to compare to. I do however wish I went with the 4600s I hear. Get things about them
ScottyBoy
Shreveport, La
Debating on whether I should clean the section that peeled off and apply new 3M molding tape. Or else should I rip the entire thing off and redo the whole thing with new double sided tape? Or else should I just rip it off and leave it off? Lol
I'd try 3M hi-bond tape if you have some or can get some but the stuff's not cheap. Mine was missing a part of it when I bought the truck and I replaced the whole strip. I don't think it was too expensive. BTW got the harness installed yesterday and was able to confirm operation of both fans. (It was 90 yesterday) But today it's cool so I didn't need them. Supposed to be back in the 90's next week though so I'll see how it does.
inmypassatlife
Just performed a legit oil change, it had been a year so I figured why not. Fram Ultra filter and 15-40 Rotella for the win!
HiHoeSilver
Away!
Chicago
Sounds like a little more air tunnel time may be necessary to determine the integrity of the remaining portion.
Escalade2007
