Good ole autoride conversion
30579it
Hey, guys. I’m new here, and have been searching the web for an answer to what I believe is a simple question:
(2001 Tahoe with 184k and G80 rear end)
I’m planning on doing the autoride to gas shock conversion. I’m looking at a setup as described in the video.
Bilstein 4600 shocks and two new rear coil over springs.
I bought the Tahoe used @147k without knowing much about the autoride system (idiot move, I know).Now I know there is a compressor which is supposed to turn on often, and air bladders that are supposed to be inflated.
My truck has none of these features. However, it throws no warning lights. This leads me to believe that the seller did something to the system to prevent it from throwing codes - maybe a resistor? I don’t know.
So, my question is, if I use a bilstein kit (4 shocks, 2 springs) is there anything else I have to buy? Will these shocks bolt on?
In some places I’m reading that it’s impossible to mount regular shocks on autoride equipped vehicles, but there seem to be kits available.
Thanks for your time, fellows.
-GFM
Dan Acosta
If the autoride shocks are no longer on the vehicle, and there are no codes, the previous owner did some conversion or modified the system to eliminate the error code. You should have no issues with the switch to your new shocks. If any of the shocks are present you may have to add a resister or any of the other solutions in posts to this forum.
30579it
Thanks for the reply. As far as I can tell, the original autoride system is still present: compressor, air bladder shocks, sensor arms, etc are all still on the truck. The dash is clear of any lights besides a random ABS light that is thrown every once in a while (faulty sensor).
———-My main question: can regular, gas shocks be physically installed on my autoride equipped Tahoe without modifying (ie. welding new brackets) parts? —————-
I’m not concerned about the code issue because the system is not functioning at all, and there are no codes being thrown. So, I feel that something has been done to the truck to erase the electronic impact of a worn out autoride system.
Thanks a ton.
Bombsquad85
Northern VA
I put in beltech 4" drop springs and beltech shocks all around all I did was pull the RTD fuse and all was solved
30579it
I’m not really wanting to lower my truck at this point because I just put some 285 tires on it.
Would regular gas shocks still bolt on if I used stock height springs?
Dan Acosta
Thanks a ton.
You can bolt them on without modifications to truck. Previous owner may have just removed a fuse or something to eliminate code. But there is no mods needed. Original Autoride shocks bolt up just like non autoride, just have some wires connected, and in rear wires and air hose. The autoride system may also be functioning properly and there are no codes. The compressor is just for auto leveling, but the electronic portion of the shock may be functioning properly - just fyi.
JetBlackNali
Vancouver Canada
20180706_151403.jpg Just upgraded the shocks as well and pulled the fuse. Rides GREAT. No more pitch and roll on those dips in a corner. 20180706_182521.jpg 20180706_153635.jpg 20180706_155446.jpg
Shocks will bolt on but the springs might feel soft due to the autoride shocks doing some of the supporting of the rear. Most guys go with the Z71 springs to compensate.
bmwme
Call me crazy but I liked the AutoRide on my 07 Tahoe LTZ. The suspension was soft for comfortable DD but would firm up a lot when the tow/haul was pressed. I actually replaced with rebuilt units when my rears went out.
01ssreda4
My bladders were busted when i got my truck. It did not ride soft, it rode stiff. I suspected the truck or shocks were incorrectly adjusting to a firm condition. I pulled it all off, installed regular bilsteins 4600s, ebay resisters, and pulled the fuse. Rode great after that.
Bombsquad85
Northern VA
If you did resistors you shouldn't have e had to pull fuse
AdrienR
