Just got a 05 Tahoe z71
hectorotani
hectorotani
Ok so went to a different store and another code came up po102 also my info center on dash says bout 14 mpg depending on speed, could my fuel gauge be bad?
Sent from my SM-G930P using Tapatalk
hectorotani
hectorotani
Under truck above transfer case I see a hose not connected is this a vent hose?
hectorotani
hectorotani
I
Mass airflow sensor, low voltage. Is it plugged in tight?
hectorotani
hectorotani
Yes to my knowledge, also I turned on truck and it fired right up then I noticed maf,was not connected,I am surprised it ran
hectorotani
hectorotani
Go back to loonytune or disconnected batt?
Scottydoggs
NJ
unhook the neg cable for 15 minutes or so. will reset the pcm.
everyone should own a cheap scanner, they can be found for $20 or less on ebay and amazon. well worth the few bucks.
Scottydoggs
NJ
Thanks!!!
you found the blue truck i was looking for lol i had three requirements when looking for mine, 04 -06 low miles had to be blue or red. a 05 red LT with 121,000 on it came up and i pounced on it, only took a year, sucks being somewhat picky.
I'm sure the trans has an issue, but you can still check the simple and cheaper stuff first: Clean the MAF. A MAF reading inaccurately can cause trans shifting issues and negatively affect fuel mileage. 14 MPG isn't terrible for your truck, especially if most of your driving is in the city.
hectorotani
hectorotani
The 14 mpg was stuck, after clicking on it reading is different, bad wont be hooked up till wed mor ,so stay tuned and I'll post results ,also was thinking gauge was reading bad
Scottydoggs
NJ
not having the maf hooked up can cause the tranny to act funny.
so id clear the codes, and see what comes back. evap is gonna need a fix of some sort. solenoid or canister tank or a cracked line is likely the issue.
hectorotani
hectorotani
I was underneath it earlier,I couldn't remove solenoid from hose is there a secret to unclamping
Scottydoggs
NJ
im not really sure, ive not had to fix one yet myself. theres loads of you tube vids that show removal of the canister tank and solenoid. seems they like to suck up dust and clog, one of the reasons for a evap code.
hectorotani
hectorotani
Actually front evap solenoid looks new and bottom was unhooked like someone messed with
hectorotani
hectorotani
Oo code clear but same maf sensor,I'm getting bout 11 miles at 45 mph, I haven't bought maf ,due to its $83 price tag lol
vtxtexan
