Look to join the family
I am looking to buy a family SUV. I am a mopar man at heart but they have nothing as big as the GM lineup. I am eyeing up two Yukon XL Denalis and wanted some advice from those more knowledgeable with these vehicles.
I appreciate your thoughts/input/suggestions.
http://www.salemautosports.com/2010-GMC-YukonXL/Used-Wagon/Trevor-WI/11170584/Details.aspx
https://www.facebook.com/marketplace/item/190061568372158
The red one looks cleaner. The only differences model year wise are that the 2010 has a USB port in the console storage. It also has the L94 6.2 with AFM. The 2009 has the L9H which does not have AFM, a big plus in my book, plus, comparing the two it is much cleaner and also has heated AND cooled seats and a 3rd row DVD player. Get the red one!
See if you can photos of the RPO sheets and or the VINs and decode them over at compnine for $5. Do you have a CarFax for each?
itsbo1313
Louisiana, MO
I just bought a 2012 Yukon XL Denali a few days ago and immediately went on a road trip over the Grapevine here in California. About 700 miles round trip in 90-105 degree temps and over 5,000 feet in elevation. Ran great, addictive power. Great vehicles.
I agree with this. Say 'NO' to AFM!!!
K
Kunze12
I am still learning about this AFM thing, but I am liking it to my former truck (09 Ram) in which it was advisable to deactivate the MSD. However, I am having trouble finding the info that tells me which models have AFM and which do not. I am thinking about taking the drive on wed. to look over the red one previously linked. But, perhaps I look at both if I have the time.
The L92 (2007-2008) and L9H (2009) 6.2 liter engines do not have AFM. The L94 (2010-2014) 6.2 liter engine has AFM. All of the 5.3 liter engines (2007-2014) have AFM. Cadillac Escalades and GMC Yukon and Yukon XL Denalis have 6.2 liter engines. GMC Yukons and Yukon XLs through SLT trim option, Tahoes and Suburbans all have the 5.3 liter engine. The only oddity was a handful of 2009 Tahoe LTZ models with the L9H. From 2007-2009 the GMC Yukon XL and Suburban also had the option of the L76 6.0 liter engine, quite uncommon.
AFM can be tuned out so while the hardware is still there, the system is not working and therefore may last longer without failing. Get that red one. As long as she has no major problems, get it.
When you're looking at the trucks, check the RPO sheet on the glovebox door. It will have these engine codes.
The L9H and L94 are Flex Fuel 6.2L engines. The LMG and LC9 are Flex Fuel 5.3L engines.
Forget all this, get that red Denali! LOL
K
Kunze12
Swathdiver,
Thanks for the that info. I appreciate your help. I really like the red one, I just need to convince the wife of it. She hates red vehicles for some reason, so I need to sell her on this one. I got her to agree to look at it so I am making progress!
Swathdiver,
My rig is black on black and I love it, don't love cleaning it all the time though. My wife loves the red. The red one from the photos looks much cleaner and the price is great. It has 2 rear DVD players and heated and cooled seats, the leather looks to be in better condition too. The engine in the red one will be more reliable too as it does not have AFM, all great reasons to buy it. I wouldn't wait another hour, someone is going to ****** that one up quick. Hope it's you guys!
When you do see it and drive, check EVERYTHING out, all the knobs and switches and features, make sure they all work. Make sure the cruise control works. It is a common problem solved for $20 that if the light for the cruise is on but it does not work, there is a switch above the pedals that needs changing. The little cigar lighter covers can be replaced, you can buy an updated navigation disc (2016 last year) or replace the whole unit with an aftermarket one. Make sure the seats work, heat, cooling, all the ways. Look for evidence of leaks in doors, carpet, moonroof, etc. Check the undercarriage for rust. Surface is fine, rot, you'll have to decide. Y'all will like the power of the Denali too. They can get out of harm's way right quick!
Some of the guys with electronic suspension will chime in on what to look for with regards to the compressor and shocks and such. @Doubeleive @kbuskill @iamdub @scot moore @randeez @mikeyss @gpracer1 @Galante
Fellas, check out that Facebook link with the red Denali!
kbuskill
NE. FL.
I am not a fan of red or the Yukon front end (looks like an oversized mini van to me) but the NON AFM 6.2L is hard to argue with.
As far as electronic ride control... just listen for the air compressor to turn on for a few seconds after start up. It should turn on for a few seconds then shut off. If you hear it running more frequently then there is a leak in the system somewhere, most likely the shocks. Not a deal breaker either way.
K
Kunze12
Where is the compressor located so I can focus on that area? Does it come on only at startup or will it turn on when ignition is turned to ACC?
Da90
Tulsa, OK
Behind the driver rear wheel.
all I can add is that at 80k expect that there will be some upcoming maintenance, shocks/air pump, fluids need to be flushed (all of them), BUY the powertrain warranty. price on either one seems pretty fair just buy the powertrain warranty so there is no surprises. that's my advice. lots of knowledge around here any issue's crop up just ask.
when you turn the key to start (not actually starting the truck) wait 4--5 seconds then you should hear the pump kick on for about 4 seconds it is right by the gas tank filler, you will be able to hear it from the front seat with the door open it's not real quiet.
K
Kunze12
I am ready to tackle fluid changes and what not. I take care of most of my own vehicles maintenance and repairs so I will check and change fluids as needed.
mikeyss
Longmont, Colorado.
The red one (09) also still have the buttons in the overhead console to fold the second row seats, it has the front door panels that don't break like I hear the owners of 2010+ models have, and the 09 doesn't yet have the active noise cancellation mics in the headliner so that makes adding a subwoofer easier if that's your thing. The biggest plus is not having AFM on the 09. The only thing you miss out on the 10' and up is the upgraded nav system and usb ports.
K
Kunze12
Went to look at the red one. Sadly, it has rust issues starting so we will not be getting that one.
Sent from my SM-G960U using Tapatalk
K
Kunze12
The black one was beat up also. Back to the drawing board. Thanks for all the help everyone.
dizhai
