100k service?
Bombsquad85
Bombsquad85
Northern VA
Two things I see.
Forget that fuel filter. Your truck doesn't have one. Yours just has the pickup screen in the pump. Also, do a little search on the moog arms. There have been fitment issues with one of them I can't remember if it's the idler or pitman. Guys were using AC delco pro for that one part instead of the moog.
Cool thanks. I'll remove the fuel filter. That's good to know.
Is the moog problem because people were getting the 3 groove instead of the 4? We need the 4. I can see fitment issues with the 3 groove
HiHoeSilver
Away!
Chicago
No, I'm pretty sure it is a legitimate "won't fit" situation. Do some searching, you'll see it.
HiHoeSilver
Away!
Chicago
My '04 flex fuel has the frame-mounted inline fuel filter, below the driver's seat. Not sure if that's because it's flex fuel or not, but it's the OEM location for this truck.
I do think flex had something to do with it. I believe in 05 nobody got it. One of those typical GM, no set change point, things.
Bombsquad85
Bombsquad85
Northern VA
That's interesting. Is that a new thing? I've been watching some videos and they use moog. But if the ac delco is recommended I'll swap that out
Bombsquad85
Bombsquad85
Northern VA
@HiHoeSilver
Ac delco professional?
And is it worth twice as much as the advantage?
Bombsquad85
Bombsquad85
Northern VA
@HiHoeSilver
Just want to say my OCD wants to thank you. I swapped the pitman, idler arm and bracket to all ac delco professional and they are all Prime lol
HiHoeSilver
Away!
Chicago
Not new. I haven't done mine yet, so I'm just citing what I've read by others as I've researched my job /mod list.
@HiHoeSilver
Yes. "advantage" is a subpar line. OE or professional, imo.
@HiHoeSilver
Again, not sure if it's the idler or the pitman. It's one of them. I know you've been open about not searching... But you need to search, bruh. Lol.
Bombsquad85
Bombsquad85
Northern VA
Lol I searched for the suspension stuff just not what is recommended for 100k service lol.
Plus I'm pretty knowledgeable with a wrench lol I appreciate you're advice tho I was unaware of the moog problem. I've had great luck with moog so far at least the problem solver line up
HiHoeSilver
Away!
Chicago
No doubt. Problem solver all day. Just looking out as there have been threads dedicated to ONE of those parts not fitting right.
Chubbs
Accessory drive belt
Type:
Service/Inspect
10K
20K
30K
40K
50K
60K
Service:
Air cleaner filter
Type:
Replace
24K
48K
Service:
Automatic transmission fluid & filter
Type:
Replace
50K
Service:
Automatic transmission shift linkage
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Brake fluid level, calipers, wheel cylinders, hoses, lines
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Brake rotors, drums, pads, shoes
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Clutch release lever
Type:
Service/Inspect
30K
60K
Service:
Clutch reservoir fluid level
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Cooling system hoses and clamps
Type:
Service/Inspect
15K
30K
45K
60K
Service:
Crankcase emission air filter
Type:
Replace
30K
60K
Service:
Engine coolant—DEX-COOL™
Type:
Replace
Replace every 150,000 miles
Service:
Engine coolant—silicate
Type:
Replace
15K
30K
45K
60K
Service:
Engine oil & filter
Type:
Replace
Change when indicated by the Oil Life Monitor, every 12 months, or every 10,00 miles
Service:
EVAP system
Type:
Service/Inspect
60K
Service:
Exhaust system & heat shields
Type:
Service/Inspect
30K
60K
Service:
Front & rear driveshaft slip-yoke
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Front wheel bearings
Type:
Lubricate
15K
30K
45K
60K
Service:
Front/rear axle fluid level
Type:
Service/Inspect
3K
6K
9K
12K
15K
18K
21K
24K
27K
30K
33K
36K
39K
42K
45K
48K
51K
54K
57K
60K
Service:
Fuel filter
Type:
Service/Inspect
30K
60K
Service:
Fuel system
Type:
Service/Inspect
60K
Service:
Manual transmission fluid
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Parking brake system
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
PCV valve
Type:
Replace
30K
60K
Service:
Power steering fluid
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Rotate tires
Type:
Service/Inspect
6K
12K
18K
24K
30K
36K
42K
48K
54K
60K
Service:
Spark plugs
Type:
Replace
30K
60K
Service:
Spark plugs—Platinum
Type:
Replace
Replace every 100,000 miles
Service:
Steering linkage
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Steering linkage and suspension
Type:
Lubricate
3K
6K
9K
12K
15K
18K
21K
24K
27K
30K
33K
36K
39K
42K
45K
48K
51K
54K
57K
60K
Service:
Suspension components
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Transfer case fluid level
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Transfer case shift lever
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Durobans
