Tire Sizes
2007Champ
I am working on my third Tahoe and this one is the 07 LT 4wd Body style but its not a Z71. I have had an 04 and 05 and I figured out what sizes tires I could run on it with the new torsion keys and wheel spacers. This 07 has stumped me a little. What is the size tire you can run without having to trim much if not any at all. It has a rough country 2in leveling kit on the front. I just want to know what my best bet is.
Howdy Alek! A little searching and I think you'll find 285 will work fine. Check out the 2007-2014 sub-forum on tires and consider posing your question there too.
2007Champ
2007Champ
Thank you I appreciate the advice. I will check there now!
Drok
Cold place in the north
I have a 2.5” lift in the front and 275 60 20 duratrac. It did rub a little bit under full turn so with your 2” lift that size would probably rub a bit more. The rubbing may just be because the tires have alot of tread vs some less aggressive ones. So i guess it really depends on the tire also.
The fender well mod was pretty easy to do and it solved the rub issue.
2007Champ
2007Champ
I am running a 275/60/20 BFG all terrain right now and I do have a slight rub at full turn. I was mistaken I do have a 2.5" lift on the front.
Escalade2007
