Stiffening up suspension with little/no drop
randeez
randeez
south florida
thanks :cheers:
should handle pretty good, speaking with the guy providing the coil over brackets he said it would be best to use a double adjustable shock up front to keep the wheels planted. At this point i think my stock shocks are about done anyway. I wanted to get everything converted over and find the ride height/spring weight i want. They should be an improvement over worn out stock shocks.
Parts if anyone interested, this will be specifically for what should be a 2" drop(I will update if different):
QA-1 DS403 single adjustable coil over shock
QA-1 COM8 106PK is a the full steel bearing kit, the shock comes with a plastic bearing that doesnt hold up long at all. this bearing kit is also 1.5" wide that matches up with the mounts.
QA-1 7888-110 spanner wrench and thrust bearing kit for adjusting ride height
Eibach 1000.250.0800, 10" 2.5"ID 800lb/in springs
Atomic F&P GMT900 coil over brackets
Planned on getting the DJM bars, Tony mentioned he started selling the Eibach sway bar set that has a thicker rear bar, so i went ahead and ordered them. I'll get some new poly end links when i figure out what length i need.
Rear shocks have been great, plenty of travel left on them to go lower, they have an "o-ring" on the shaft that lets you know how much theyve traveled - in one of the pics it's only about an 1.5" up guessing thats where it hits the bump stops at the moment. The parking brake cable on the driveside was on the shock and started to wear a mark in it, I pulled whatever slack there was in it to the back and tried to form some more bend in it and it seems to be away from it.
randeez
randeez
south florida
Welp already messed up :lol:
Brackets arrived, awesome fast shipping, powder coated.
bearing kit is wrong. Needs to be 1"wide not 1.5".
The bearing included with the shocks is the right size but plastic/poly. Correct part number is com8t-102pk.
randeez
randeez
south florida
That girth :eek:
Thanks again Tony! @NORCAL SS and retarded fast shipping...I think I payed Thursday night..delivery was supposed to be monday but weather delayed to tuesday
992dr
Eastern N.C.
What are the size differences between the stock and aftermarket sway bars?
Are they hollow?
Do they come in black?
They look great.
randeez
randeez
south florida
Are they hollow?
They look great.
not to sure on stock size, looking at replacement bushings for stock seems to be 30mm or 36mm(ppv?) front , and 29mm rear. These are 38mm front/ 32mm rear as shown from the manufacturer
says "tubular" so im guessing hollow, shipping weight of 41lbs seems pretty accurate.
i havent seen them in black from eibach, about every other manufacturer is tho
correct bearing came in, still waiting on thrust washer and spanner set. hopinggggg it gets here by friday so i can put it all in this weekend
992dr
Eastern N.C.
Thanks for the info Randy, much appreciated.
I certainly hope you get everything by Friday, I'm dying to hear a review on the new set up.
randeez
randeez
south florida
wasnt sure if parts are coming in to get coilovers done so i went ahead and put sway bars in.
both bars are a very easy to do provided all the hardware isnt rusted to hell. mine wasnt to bad, had one front bushing bolts start to round off the head - was using one of those husky "universal" sockets. I grabbed a regular 6point socket and saved it though, came out and went back in clean. with just the drop spindles shorter links up front arent necessary. I will need some when i drop some more so i put old ones back on. the eibach bars only come with new bushings, they reuse the stock "straps"
Both of the eibach bars were not, physically, much larger in diameter than my stock bars. the stock 36mm/29mm F/R is probably true to the eibach 38mm/32mm F/R. however in weight the eibach bars were substantially heavier and thicker. simply hitting the stock bar against something/ground would sound like a hollow pipe, where the eibach would just thud.
rear bar is getting closer and closer on the passenger side to the shock, i will probably play around with the panhard bar this weekend and try to get a little more separation
Only got a little bit of seat time so far, I will be able to notice more of a difference on my normal driving routes so i'll update in a week or so prob.
Not much pics...a few sidexside of rear bar
randeez
randeez
south florida
Nothing showed up.
but I didnt want to wait, and i had a little calm between rain storms
So i put together the coil overs, put a little pre load on the spring (about 9.5" installed height) , jacked the truck up. swapping them out is pretty easy actually- it was nice.
got the first one in assembled it all loose, everything looked good so i tightened it down.
moved on to the other side, no problems everything went pretty smooth.
took first side off the jack stand, let it down to the ground - it was noticeably lower (still having the other side on jack stand tho) thought alright not bad.
took the other side off the jack stand and started lowering....lower...lower...lower.... jack stuck! :lol:
was wayyyyy to low, tires buried in the wheel wells.
jacked it back up, took another inch out of the spring (about 8.5" installed height), tire back on, lowered back down, was still tucking tire. back up one more time, down another 1/2" - tires back on back on the ground etc... and tires were about even with wheel well :eek:
soooo im thinking springs need to be a whole lot heavier, jacked it back up, threw stock shocks/springs back on. got rained on , it sucked...onto some more research :chewie:
992dr
Eastern N.C.
The bars look great. I'll eventually replace mine with some aftermarket ones. I was eyeing Hotchkis bars.
Wowza, that's loooooowwww hahaha.
When you ordered your brackets from Richard, did you go over your set up with him to spec out the correct size/length of the coils/shocks?
From what I've been reading, 1200lb coils seem to be a popular rate. I think 800lbs is too light.
I'll be going with 1200lbers when the time comes.
randeez
randeez
south florida
yea, talked it over with him.. i actually just email him to see how much preload i should be setting them at - they bind about 5" so i dont think any more than i did would work. I wait to hear what he comes back with but he seemed to think it would be OK for 2" of drop when we talked before
without the drop spindles these would have probably have been a solid 3.5-4" drop by themselves
thats what i'll be looking at 1100-1200lbs springs, only off the shelf ive seen them in is 12" long
randeez
randeez
south florida
I did do *something* productive today...
Flipped the rear shocks :D
Driverside was getting rubbed by the parking brake cable, passenger side was rear close the the sway bar.
Found out it doesn't matter which way I mount these shocks flipping them frees up some space.
992dr
Eastern N.C.
That was quite a bit more than 2".
Are you sure they're the correct length coil-over?
View attachment 200325 View attachment 200326 View attachment 200327
That's a great idea.
Wow, that's crazy. It actually wore some of the material away? Are the bodies aluminum?
My drivers side rubs on the shock as well but hasn't worn through like on yours.
randeez
randeez
south florida
Lol yea, I'm 2x checking every thing and going over it with richard(atomic) seems weird measurement from center of hub to fender is 18" now, which he thinks is a 4"drop so I dont know.
Yea the rubbing sucks, it's not as bad as it looks she shocks are just polished so it shows horribly
And my service traction/abs/etc light is on now.. gotta crawl back under make sure I didn't pull a speed sensor or something on accident
Took a few picture to try and show the depth yesterday but :
992dr
Eastern N.C.
I just ran out (in the pouring rain :) ) mine measures 16" from center of hub to fender. I'm on 17s w/275/60 tires which is a 30" tall tire.
What size tire are you using?
I think the most accurate way to measure is eye to eye on the mounts at ride height.
Ooh yes, you are correct it certainly looks worse than it looked in the first shot.
Mine was set off too, it turned out to be my passenger rear sensor was unplugged.
I see, its worn but as bad. It did rub a little material away huh?
randeez
randeez
south florida
275 55 20 - 32" tire, center to fender on mine is 18.5"/18.25. I really only want to go down another inch or so. we'll get it figured out
fender gap on mine still looks pretty big, but it's only about 3"
he's saying he usually sees stock fender height at 22" center to fender. I may have to put the mounts all on, put the tire back on and lay it out to what height I want and then order, which would suck but i still need heavy spring
the shock I have is only like 3/4" shorter than the stock shock/spring. but with the 800lb/inch spring i'd have to preload it to under 7" (from 10" ie 2400lbs :eek:) and that only leaves me 2" of compression left, which is probably fine but not really ideal.
the 900lb/in spring from hyperco to preload 2400lbs i would need to compress to a little under 8", that might be the easiest/cheapest to get something in there in the short term .
still trying to find heavier springs on the shelf, not goin so well
992dr
Eastern N.C.
You'll get it figured for sure. What total drop are you going for?
Ahh, the joys of modifying our rides haha. Put it on take it off, put it on, take it off again and again and again and again,,,,,,,,,
You should be ok but, like you said not ideal.
Is it that the coils aren't available for that specific shock or just not available at all?
randeez
randeez
south florida
arent available, cant find much over 800-900 lb/inch. these coil overs use a 2.5" ID spring, 10" long other shocks use a 12" which i cant find anything heavier either
not very popular to put coil overs on something this heavy it looks like
992dr
Eastern N.C.
That's what makes me a little nervous.
I'm curious to know what coil-overs others are using. I believe Richard said Vikings are popular, I was looking at Ride Tech. I'm going to have to look around to see who has the most options.
Is it the body size of your shocks which doesn't have many options?
I agree. I've seen more and more pickups converting but, not many full size SUVs.
randeez
randeez
south florida
the viking atomic sells are also for 2.5" ID springs. they would need a larger spring seat to use 4-5-6" diameter springs
I asked him how much preload am i supposed to set them up with, if he says crank it on down, i'll give it a try...the 900lb are only like 60 bux each i'm going to grab them and go for it
need to set a couple of bolts in the work bench for setting the preload up....kinda pain in the ass tightening the thin jam nut up on truck 1/8th of a turn at a time
jpurdie
