Adding USB to dash...
Meccanoble
Georgia
Nathan, I'm trying to understand your explanation above. I'm trying to push the silver part deeper into the hole so it cant be seen but will have a usb cig charger connected to it and that is also pushed inside the hole as well. That white cable, where is it going to? I see it goes to the dash hole but where does it connect on the metal part? I thought it would connect in that usb hole that we see near green LED but looks like its connected elsewhere?
Any instructions on how to pop out the charger in the second row? I would like to run USB/AUX from there (USB to charge but not sure whats involved with popping that one out? Even if the concept was the same (twist or pop from metal points), the rear seems to need removal so the connection can be hidden behind (if there is even enough space)
Am I doing too much here? It seems like to get the entire piece to fit through the hole, I have to make the original mounting hole bigger
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
You'll have to take the silver part out (pull it out) and then remove the black ring around it, and then you can hide it.
This is how it will come out...
Definitely can be done.
You can remove it like it shows in the pictures and unplug it and then push it into the dash.
I'm not trying to be mean here, but if this doesn't make sense at all, you might want to pay someone to do it so you don't mess up your dash. Maybe take it apart and look for yourself and see if it starts to make sense.
Meccanoble
Georgia
Yea I do better with visual and even then, I really need to see it to truly understand but your feedback is helping a lot.
Focusing on the cig lighter in the second row under the rear audio controls. When I pop up cover, I should be able to pull the silver part forward after pushing on the black pieces holding it in its place. Then it looks like the cover/surround can be twisted off. I should have access to what I need from there. I'll take a look, thanks.
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
pulled out, yes
No problem. Let me know if you have any other questions once you get in to it. Like I said, it might make more sense once you're in their and see what I'm trying to explain.
Ejbarah
kuwait
I just purchased OEM one for my 2009 Tahoe from eBay come complete bezel for 19.95$
2007-2013 Silverado Escalade Dual Power Receptacle Cigarette Lighter & USB Bezel.
if anyone interest here it is
eBay item number:
231895107012
eBay item number:
231895107012
Nice deal. Had I known this was an option I surely would've gotten it instead of retrofitting my original one.
CHOO CHOO
BackPagePhil
Manheim, Pa
eBay item number:
231895107012
Just ordered this, thanks for the link. I'll post up how it installs when I get it and get a chance to install.
richborba1
First, I did this for my aftermarket Pioneer 8400BH head unit.
For people who have stock Navigation and have the USB in your center console, this is the same thing, using the same wire to your head unit, just in the dash instead of in your center console. SUVs get the USB in the center console, Trucks got the USB on the dash.
This will play music and video files from my iPhone, iPad, thumb drive and a regular hard drive. However, on some instances there's not enough power to start the hard drive, so you will have to power it up using the power cord to a cig lighter adapter or something else. It will also charge my iPhone as well.
Part numbers:
USB Cover Plug - 20983937
USB Receptacle (in dash) - 20944422
The only difference in the cover is it shows the USB symbol. The plain cover on your cig lighter will work. See this thread for more info as it's the thread the idea came from...
USB cigarette lighter port
On to the pics...
Remove radio surround
2 7mm screws to remove the cig lighter piece.
Then there are 2 clips holding the cig lighter in place. You have to open the cover to pull the cig plug out. and then 2 clips to get the cover off
Put the USB cover back in place
push the USB receptacle back in
Using an aftermarket USB male to mini USB male adapter, pug the mini USB in to the back of the new receptacle and the USB in to the back of your aftermarket radio.
Put everything back together just like you took it apart and your done...
Edit:
For those of you that want to add USB charging only, you can simply get a USB cigarette lighter adapter and tuck the main part behind the radio like this...
So I did this also on my 2011 Silverado using that cable but now my issue is car play wont work well. Do you use car play also? How does it work?
