Scottydoggs
them thin ass pads from yesterday.
You lucked out--BIG TIME! Caught that in the nick of time.them thin ass pads from yesterday.
Lets see how it goes the truck is on keys and there plenty of room with the 285 on it now.
I think I probably would've just let the boss worry about it--but, I bet if you did do that, the truck would be down, and you guys wouldn't be able to work. Am I guessing correctly?that was one day of light squealing, then the next day full blown, so loud i could not tell if it was front or back.
plan was to dump the truck then bring back a load of mulch, dump it on site, then go do the brakes. i barely got the pads picked up and back to the house to work on it, and i get the call, come back, i cant be waiting all day, you been gone over a hr already, really? ive been gone 35 minutes so far, you forget travel time? so i loaded up the jack and tools cause i knew it was a matter of miles before the rotors got eaten up.
under the truck doing the brakes, im like you do know i just saved you 150 bucks right????? no way they would have lasted another trip with a load of mulch.....
How'd you get the majority of the trans fluid out? Cooler lines or drain plug?Oil change and trans fluid/filter change. At 215k.
those look damn good.New headlights and signal lights came in today! Had some issues with a blown fuse for the turn signal because I didn't pay attention to polarity, and I can't figure out how to turn the DRL's on. But it's installed!
View attachment 198599 View attachment 198600
Or pull up the a window in the day time and see the reflection @Isaiah Wthose look damn good.
the drl lights, e brake on, key to run, put the truck in drive, they will then turn on. they only work when the trucks in gear.
