Tonyrodz's Tahoe Build Thread
HiHoeSilver
Away!
Chicago
If you do a search, there's a GM person on here that'll send them for free. You have to pm them, but I don't remember who they are, lol--I'm old and forget alot!
It's @GM Customer Service
Although, they don't seem to have been replying as well lately. Send a PM with your email and VIN kindly requesting your build sheet. If they done get back, @Doubeleive has a live chat link you can ask for it from.
you can get it faster, just go to the gm website, select chat, then for the subject choose "question about a vehicle I already own", then provide the representative your vin and they will provide you with the build sheet, they are open m-sat regular business hours, closed sundays.
NGAneer
NWGA
Dang right it's faster. Had mine in 5 minutes after reading this.
Jlaughtr
Deming, NM
DUDE! That was super easy and fast!! Thanks :cheers:
Drilling a hole in your interior to mount a switch is like getting a tattoo. It's not something you should do without much deliberation. But, it's an idea that has to come to you on it's own. I'm sure that one day, Tony will have a revelation and find the most perfect location for that switch.
So, Tony, that fenderwell gap about which you said "more on that later"- spill the beans, bub. :D
Switch is still hanging:D.
Onebad1983
Resident Country Dumbass
Lubed all the zerk fittings in the front end. Both lower bj fittings(zerks) just came out in my hand. Was a *****, but I got them back in, but I think they might've been clogged because all the grease just came out along the side of the zerk as I was puttung the grease in. I know I'm gonna do both upper and lower control arms on both sides eventually, don't wanna bother with pressing in new ball joints. Still need to do both front axles. Driver side boot is torn to hell and passenger side is slinging grease. All that grease plus the tranny fluid and oil under there--this baby will never rust! Lol
Good work keeping your frame lubricated from the NE salt! Errr winning? Lol
Lol, ummm, I think? I figured it can't hurt, much. When the weather gets warmer I think I'm gonna clean it up with my power washer--and the dog too! Lol, she stinks so it can't hurt either.
Fosscore
Ok, thought this was an exhaust leak because header bolts were loose. Tightened them but noise is still there. I can't tell if it's exhaust or under the valve cover. Def noise from the top endsomewhere. Opinions or suggestions?
Hood closed.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Did you put headers on? Couple things you can try. Take a piece of vacuume hose or pick up a stethoscope. Move the open end around your suspect area of leak. You’ll hear puffs of air of there is a leak. Secondly I see you put wires on too. Check to see if any of the plugs loosened up and need retorqing. Third maybe your manifold gasket got tweaked. I’d recommend oem but they are expensive. I picked up a set of fel-pro gAskets and also picked up some copper gasket spray. Coat the gaskets with it and it helps seal better. If all else fails, it may just be noisy injectors or if you do have headers it may be normal exhaust scavenging your hearing. Aftermarket Headers are nowhere as thick oem so it’s gonna sound a little funky. Here’s a video of mine after doing everything I mentioned above.
X-ray Nerd
